Question about Jabra BT4051 Bluetooth Headset
Need pass key for jabra bt4051
We are trying to set up the bluetooth for a PS3 system and need a pass key.
Posted by Tammy Christianson on
reelection
    New Friend:
  • 4 Answers
0000
Posted on Dec 28, 2011
How do I find the pass key to connect my Samsung Bluetooth keyboard to my ps3
Hi Richard
Try putting in 0000 this is normally a default pass code for most Bluetooth items hope this helps
Nov 27, 2014 | Sony Playstation 3 (PS3) Console
How do i get my pass key for broadcom bluetooth usb
go into the ps3 and see if the device is visable, if it is set accordingly
Jan 25, 2013 | Sony Computers & Internet
Need a pass key for my plantronics explorer 233 bluetooth
I would try 0000 if it is a brand new headset that is the universal default password for those hope i could help =]
Feb 29, 2012 | Plantronics 233 Bluetooth Headset
Kindly help me connect my samsung HM1100 bluetooth headset to my playstation 3
1) Go to "Settings" on your PS3.
2) Scroll down and select "Accessory Settings."
3) Select "Manage Bluetooth Devices."
4) Select "Yes" when the message "The Bluetooth device has not been registered. Do you want to register?" is displayed.
5)
Turn on your Bluetooth headset when asked by the message "To register (pair), you will need to prepare the Bluetooth device. For information on preparing the device, check the instructions supplied with the Bluetooth device." While each Bluetooth headset is different, for most this means to hold down the power button until the blue light on the device remains solidly lit.
6)
Select "Start Scanning" once your Bluetooth headset is in "pair" mode. Wait for the PS3 to scan for your Bluetooth headset. If the scan was successful, your Bluetooth headset will be listed on-screen. Select your headset from the list
7) Refer to the Bluetooth headset's instruction manual to find the pass key for your device (Usually the pass key is something simple like "0000" or "1234". Press "X" to bring up the on-screen keyboard and enter the pass key. Select "Enter" then "OK." "Register Completed" will display to confirm a successful connection.
NOTE: If the headset does not display after a scan, it may not be compatible with the PS3, or it is not properly set to "pair" mode. Refer to your Bluetooth headset instruction manual for directions to properly set your device to "pair mode."
If you want to check the User Manual for your Bluetooth, simply click on the following link:
http://www.samsung.com/us/support/downloads/BHM1100NBACSTA Click on the Icon below "File" Thank you.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
My madcatz bluetooth isnt found by my ps3 how do i fix
i need the pass key for my mad catz 8860 bluetooth head set
Aug 22, 2010 | Mad Catz Bluetooth Headset for PS3
PS3 Bluetooth® Headset Wireless Headset: i need a pass key for my bluetooth headset model #...
First try '0000' (four zeros). If it doesn't work, switch to '1234'. It it keeps failing, try '8888'.
Hope one of these codes might suit your case.
Cheers! Carlos
May 17, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
PS3 Bluetooth® Headset Wireless Headset: lost my pass key...
Cheers! Carlos
Insignia disk does not read from Playstation3
if the headset is bluetooth then the ps3 should be able to connect with it while its in pairing mode form the settings menu. if the headset will not function without other software then the ps3 cannot use them. the ps3 will only read the select music, video, and game discs.
Jul 25, 2008 | Insignia Bluetooth Wireless Headphones...
Jabra BT4051 Bluetooth Headset Logo
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Mosaub Al Masri
Mosaub Al Masri
Ekse
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
