Blodgett DFG-100 Gas Single Oven Logo
Ralph Introna Posted on Dec 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Carbon monixcide smell when running ?? - Blodgett DFG-100 Gas Single Oven
Steve Allison
Level 3:
  • Blodgett Master 5,569 Answers
  • Posted on Dec 27, 2011
Steve Allison
Blodgett Master
Level 3:
Answers
5569
Questions
Helped
2002450
Points
16452
Carbon monoxide is both odor- and colorless, making it very dangerous. It has no characteristic odor.
Strong gas odor only when oven is in operation?
If you're talking about the acrid smell immediately after starting the oven, that's aldehyde gas, a byproduct of cold gas combustion where the flame contacts the cold metal oven surfaces. That smell should disappear within the first minute or two, and it's entirely normal for a gas oven. If you're talking instead about the smell of fuel gas, then your burner may need to be adjusted; it may be running much too "rich".
Kitchenaid superba microwave not working smell
Junk it and buy new, do not run this anymore may catch fire.
Carbon monoxcide smell when oven running ?
I have to assume your oven is gas-fired but it helps to have make and model info.Carbon monoxide is odor- and colorless; that's why its dangerous. I don't doubt that you have poor combustion and it may well contain the gas in the fumes. Check for yellow flames which are a sure sign of an improper gas-to-air ratio. If you do, you may have a buildup of residue causing the problem.
Dec 27, 2011 • Ovens
Does an electric oven need curing before I cook in it for the first time? If so, how long and at what temperature?
you can run it at 350 for like a half hour or so and you'll smell a funny smell from the metal heating up,when i replace an ignitor or an element i run it for like 10 minutes just to burn off the smell of the metal.i'm sure the factory already had that fired up to check it but i would start it and burn anything off of it that might be in there before i cooked anything,it can't hurt it.good luck with your new machine.
3helpful
I have fitted a new element to my creda fan oven but when i put the oven on it smelled of burning is this normal
You can expect it to smell for a while, as it is a protective coating on the element.
Run it at a high temp for a few minutes with the door open if possible, this should get rid of the smell.
Hope this helps.
Dec 15, 2009 • Ovens
Strong Foul smell coming from oven only when I turn it on
do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
Glass top and oven 7 months old still has the new oven smell
possible that the insulation that surrounds your oven cavity has yet to fully cure, i would run a clean mode, this will get the unit to max temp fro 3 hours, fully curing any insulaton for sure
Vapor Smell
DO NOT OPERATE THE OVEN UNTIL YOU GET SOMEONE TO CHECK IT THAT IS FAMILIAR WITH A GAS STOVE!!!
It is very possible that the oven is not burning clean and this will release carbon monixide into your home. This could be very, very dangerous.
If you have just purchased the oven, then it may need to be set up for the type of gas you are using.
If it is not new, then it may have some problem with the air intake to the burner.
It could also be something harmless such as a spill that is burning off, but if you are not sure what it is, please take the safe route and do not use the oven.
This is not a problem that can easily and safely be determined from an internet website. A competent gas repairman needs to look at it if it is burning your eyes.
I understand this answer may not qualify as a fixya rating for you, but I am more interested in your safety than my rating when it comes to a possible dangerous problem.
Please be safe.
Thanks/Mike
Dec 01, 2007 • Ovens
Neff Fan oven
Probably unburnt fat, run the oven at full temp for about one hour this should resolve problem
Regards
Advisor
Nov 15, 2007 • Ovens
Top Blodgett Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
