When i set up my email it downloaded evry email i have ever recieved going back to 2006. As faras i can tell i have to manually delete each one. Is there any way to delete them all at once? I cannot download anything else and i suspect its my email thats the problem
Left click on the top email one time so it is highlighted. Then move your mouse down the list as far as you can go. Then push and hold the "shift" button on your keyboard and click the left mouse button on the last email you can reach. All the emails between the top one you clicked and the bottom one you "shift and click" should light up. Now push the "delete" key on your keyboard and all those that are highlighted will delete. Whatever you can do to highlight more emails will delete them quicker.
Standard instructions for email inbox setup:
i have finished my corby pro email settings & i can send and recieve emails. the problem with only recieving & not able to send is the confusion between port numbers. in secure connection box three options available ' off ', ' SSL ', ' TLS '. use only SSL or TLS because the port numbers for SSL & TLS differs. just try this & you will be able to send and recieve emails.
SMTP port - 465
POP3 port - 995
Enable POP in Gmail. Don't forget to click Save Changes when you're done.Configure your client to match the settings below:Incoming Mail (POP3) Server - requires SSL:pop.gmail.comUnless you're using recent mode to download mail to multiple clients, make sure you've opted not to leave messages on the server. Your Gmail settings determine whether or not messages stay on the server, so this setting in your client won't affect how Gmail handles your mail.
Please note that if your client does not support SMTP authentication, you won't be able to send mail through your client using your Gmail address.
Also, if you're having trouble sending mail but you've confirmed that encyrption is active for SMTP in your mail client, try to configure your SMTP server on a different port: 465 or 587.
You're now ready to use POP with your Gmail address.83 views
