Question about Philips 43P8341 43" Rear Projection Television
No picture led blinks four times - Philips 43P8341 43" Rear Projection Television
Posted by thomas hardesty on
Red LED blinks four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 26, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
Sony tv kv ha21p52 the picture is shrinking in bottom few seconds the set goes to stand by the led bilinking four times plz help me
Mar 23, 2014 | Televison & Video
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Sony crt tv (KV-BZ14M70) led blinking four times in stand by mode, so it means?
Hi Ullah,
LED blinks four times on KV series means that the Vertical deflection circuitry encountered a problem. You can repair it yourself if you have knowledge in electronics, knowledgeable in soldering and desoldering of parts on the board.
[email protected]
Jun 14, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
What's your problem?Hi, I have a Sony projection TV KP-46WT510 theres no picture or sound, but it still turns on and I can see the the on screen menu. When I turn it on the led blinks four times
You can Google and find the service manual which will explain what the 4 blinks means.
If you have the Sony remote with the set off:
Display, 5, Volume down, Power
If the set has it you will see a box appear on screen with a list of items--all should have a zero to the right of each---one with a number indicates the number of times that error has been detected.
Let me know if you have questions or cannot find what the four means and I will research it.
Mar 28, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
My philips 50p8341 beeps then flashes the red led 4 times
4 Blinks means that an incorrect voltage had been detected on the +5V circuit coming from PSU to digital control board.
The PSU must be tested and eventually repaired or replaced.
Aug 08, 2009 | Philips Televison & Video
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Need rca univeral remote code for a toshiba tv
1. Manually turn on the component you want the remote
to control.
2. Press and hold the component key (TV, DVD•VCR, AUX, SAT•CBL) you wish to program. The LED INDICATOR turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the LED INDICATOR blinks four times, and the process is exited.
3. While holding down the component key, enter the four-digit code. While you are pressing the numbers, the LED INDICATOR turns off.
4. After the fourth number is entered, the LED INDICATOR turns on. At this time, release the component key. If the LED INDICATOR turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry.
If the LED INDICATOR blinks four times when the component key is released, This means that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2.
RCA Toshiba 3 digit codes. 000,018,021,023,048,049,071,072,073,085,...
RCA Toshiba 4 digit codes.1000,1048,1072,1105, 1109, 1118,1160,1190,1241 Good Luck
Jun 14, 2009 | Televison & Video
Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 04, 2009 | Sony KDS-60A2000 60" HDTV
Philips 43P8341 43" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
