Question about Acer ~ Aspire 1.5GHz Pentium M 512MB/80GB DVD-ROM Notebook Computer (10088363000) PC Notebook
Black borders screen size has shrunk
Posted by jimmie hand on
Chris Hingee
  • Acer Master
  • 32,281 Answers
If you cannot adjust the screen resolution then install the latest video driver and then adjust the screen resolution to 1024X768.
Download the video and device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Posted on Dec 26, 2011
When I play dvds or watch videos on youtube the screen has a black border on both sides reducing the size of the screen
If you hit full screen on the youtube video and its not full screen, then it sounds like your monitor resolution is to low.
Rt click on a place on your screen and pick screen resolution, then pick resolution and increase it.
The first number is width, so say it's on 800x600 then go 1024x768
Apr 05, 2013 | ASUS Computers & Internet
Sony Wega Trinitron TV image has shrunk?
Check its main power regulator section circuit for any loose solder terminals. Low power regulator voltage output is the problem to your TV.
Nov 19, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Black border with some channels
if you mean the left and right sides of screen, look for a button on remote might be labeled several things, like picture size, aspect etc.. the borders pop up when you go to a non high def channel. some chs put borders all around the picture in those cases you won't be able to get rid of those.
Apr 07, 2010 | Memorex MVDT2002 20" TV
HELP! Laptop screen has shrunk... black border on screen.
Big Lebowski - this refers to an issue with a laptop.
No CRT on a laptop.
It is more likely a driver issue.
Go to dell.com, look for support, put in your service tag & update the graphics drivers.
Nov 16, 2009 | E-Machines eMachines Desktop PC
Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Dell Inspiron 8200 Notebook
Vertical size
convergence problem , ic replacement
Nov 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Screen display size on Thinkpad A22p
your system might have damaged the systems video drivers and reverted to legacy.
try to re-install the display drivers again.
if you look in the system/device manager for the display it may just say vga , which can only give you 800x600 native mode.
if you right click on the desktop /properties
advanced /display adapter it should have the name of your video card.
Apr 30, 2008 | Computers & Internet
My screen has shrunk half the size
THE PROBLEM IS IN MONITER THE YOK IS DAMAGED THAT WHY THESE PROBLEM ACCERS
Mar 25, 2008 | Gateway FPD2275W LCD Monitor
C840 resolution difficulties...
The type of screen you have is a UXGA screen. the optimal resolution for that is 1600 x 1200. changing the resolution for that will distort the screen causing black borders. If a computer has a 15.0+" SXGA+ screen with an optimized resolution of 1400x1050 and the screen's current resolution is set to 1280x1024 pixels, the display will shrink resulting in a black border surrounding the edges of the screen. Also, all other lower resolutions may be stretched to fit the screen. No border will be visible, but fonts may appear slightly fuzzy.
Oct 03, 2007 | Dell Inspiron 8200 Latitude C840 Laptop...
Computers & Internet Logo
70 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
