The following is not a solution but a set of steps to determine an issue. Wire the router back up -- connect a computer to it using a wire -- can it access the internet? If so the WAN side router config is fine. The issue appears to be a wireless issue. Did the wireless card lose the proper configuration settings to access the router? Did the wireless adapter disconnect and need to be reconnected?
If nothing above was an issue we need to do some other testing -- I do not believe this is likely in this scenario where things were working -- but as we have not yet found out a cause.
Turn all machines on before the test and do not turn off until after
On
at least one wired computer that is working and one wireless computer attaching to the linksys router
I want you to do the following
Click Start then All
Programs then Accessories then Command Prompt
In the window
that opens type
ipconfig /all
press enter then record all of the
following for each
adapter
The back in the window enter
the following command using the default gateway from the wired connection (your
router address)
ping 192.168.1.1
you will either get 4
timeouts -- the connection fails or 4 messages with elapsed times generally
measured in ms or milliseconds.
What you are looking for in the above
Good entries base
u
should be unique for the linksys
networkWired IP address 192.168.1.u
SubNet Mask ?.?.?.? assuming 255.255.255.0
Default Gateway
192.168.1.1
DNS addresses ?.?.?.? not 0.0.0.0
where at least one is not zero.
Then wireless entries should be
Wired IP address 192.168.1.u should be 192.168.1.u
SubNet Mask same
as wired
Default Gateway same as wired
DNS addresses same as wired
If
these are wrong there is a configuration error either in the router or wireless
adapters depending on how you want your network setup.
each connected
adapter wired and each wireless should also
successfully ping the default
gateway or router address
If the ipconfig is right and the wired config
has successful pings, then every wireless adapter that fails has a wireless
config issue.
If you are willing to work through this let me know and
reply with information in a comment to this issue.
