I cannot turn off the progressive scan mode on my VIZIO M221NV LCD tv. I need help
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on. If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
SOURCE: Vizio 42" 1080p HDTV LCD.
This is likely due to heat expansion (turned on) and contraction (turned off).
SOURCE: 46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
For the 46" TV, it sounds like the main board is bad.
For the 50" Vizio: is the LED light on?
SOURCE: Vizio LCD DTV 32 inch. Model L32. I can't 'scan'
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
