To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
SOURCE: Sylvania 7" smartbook "synet7wid"
Go to this website. Download the "OS Update" zip file. You'll need to unzip it to a blank 1GB SD card (they say at least 1GB, but I used my 512 and it fit). Then you put the card in the slot UPSIDE DOWN WITH TABS FACING UP! Turn on the Netbook and the entire OS will self-install. Sometimes you need to do this more than once, apparently. Just remember, this is going to ERASE your entire netbook and do a clean install of the OS. The step by step instructions are also right on the page; here's the link:
http://www.sylvaniacomputers.com/product.php?id_product=41
Best of luck to you.
James
SOURCE: I have a Sylvania smartbook
Take a look at the following detail and see if you can apply it to your smart book.
It is looking for apassword (WiFi Network Key) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on it's backand using a toothpick, insert it into the little hole about an inch diagonallyfrom the right corner of the data plate, this will re-load a new copy ofeverything including the WiFi RT28701 driver.
Some times thisdriver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
AdditionalInformation
When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the automatic sign on has not found a viable network, or needssomething else. If I then click on Wireless Information tab, the list ofavailable networks, appear in the box. The machine keeps trying to associate myprevious entered name site with my preferred site and tells me the signal isgood, but it cannot link up. This is a signal to me that it has lost my NetworkKey or that the softwarehas failed or both. I then click on advance and delete my preferred network andhit OK, this will force the software to ask me for my network again, and noticethat the preferred is missing. I click on the name of my network again and thenhit connect., then the Wireless Network properties window opens up and I caninsert my Network Key again after I uncheck the "The key is providedautomatically" box. I enter the key and hit the OK button. I still do notget a connection, so I reboot the machine, and wait for about 30 seconds andthe machine synchs up because the little RED X under the icon has disappeared.Now the machine will hook to the internet as long as I want to, but sometimeswhen I turn the machine on it will not synch, so I go through the abovesequence again. The secret is once you have entered your key and ask for themachine to synch up you have to reboot. Why? I do not exactly know, but Isuspect that the WiFi driver looses it
You may also wantto look at the TIP http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard To make your knowledge complete
SOURCE: I have a Sylvania 7"
Hello, your Sylvania is classed as a mobile device and wont play normal pc files.(it can't handle flash files) You have to browse to the youtube mobile website in order to get them to play. Regards, nicam49
