Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
I forgot my westell password i need it for another laptop because i just got another laptop and i need the password
Posted by zack wise on
  • Dennis Engelking Dec 28, 2011
    Are you talking about the Router Addmin Password or the Network Security code for the laptop
  • Westell Wire... Master
  • 7,733 Answers
2 OPTIONS
1-RESET THE ROUTER - http://www.fixya.com/support/r11153882-general_routers_reseting
2-USE A PASSWORD RECOVERY APP LIKE Download self-install executable for installing BulletsPassView with uninstall support
Posted on Jan 07, 2012
How can I set up a password on my Ipad2 through my internet carrier "Westell"?
Who set up your Westell wifi security? They will know the password. Otherwise you have to reset the network password.
Forgot ssid password
Where are you entering it? (In the router it should be) and simply enter "change password" you will then need to enter this new P/W into your laptop / PDA / iPhone etc.
I have a Westell 327w My companies laptop connects fine but my daughters laptop will not. Her computer can connect to other wireless just not ours. Any help greatly appreciated
hi
may your wirless is prodected by password
just folow the setp
click on wirless icon on screen try to connect it will ask you password
if you don't know the pass then
in explorer type your IP e.c. http://192.168.1.1
then it will ask router password just apply then you will able to see your wireless password from the router setting
1helpful
Forgot username and password how do I fix this westell 327
Did you forget the user name and password for accessing the Web Utility of the router? If yes, you need to reset the router back to it's factory state. There's no other way but to reset it and then reconfigure the router. Set a new user name and password.
Regards,
Firesnake09
I need the key towestell 327w router
The default user/password is "admin" & "password". If that doesnt work then you'll need to reset the router if you forgot the login password. The tiny reset button is on the back or underside.
2helpful
2answers
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
2helpful
Westell 327 modem is listed on itouch; itouch asks for password
lock on the botom of the router it might be locking for the WEP password on the label
12helpful
4answers
Westell versalink 327w i need default password
If the 327 was never set up for wireless you need to connect to it with an Ethernet cable and plug that into your Mac and one of the RJ45 ports on the back of the 327. Type http://192.168.1.1 into your browser, this should take you to the Westell Home Page (Your Router). The default for wireless in this router is disable. There are tabs across the top on the page, select Configuration>Wireless>Basic. This opens the Wireless Operation Window. If Wireless is disabled, click arrow to enable. You can also enable and disable encryption in this same window and if you choose to use the basic WEP in the device, the WEP key is on the label on the bottom of the router. If all this is good your laptop should be able to detect the wireless connection, the default is the serial number on the bottom of the router so you will know which connection is yours. REMEMBER TO CLICK SAVE before exiting the window! Hope this helps.
2answers
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
1helpful
2answers
Problem accessing router
You can try the link below and see if you can get the default password..
http://www.routerpasswords.com/
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Mehandi Husain ...
Ekse
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
