Question about RCA D61W20 61" Rear Projection Television
Power light turns on for 10 seconds then off. won't
Posted by Dave Williams on
Matt
    New Friend:
    Problem Solver:
  • 5 Answers
There may be bad capacitors on the deflection board. They are the round cylindrical things with shiny tops. You will need to pull the board out to see them. Make sure they aren't bulged or leaking. You may also have a dead high voltage circuit. If you aren't experienced in electronics then I would leave it to a professional because there are high voltages on this part.
Posted on Mar 12, 2012
5 Related Answers
graeme ian hunter
  • 1288 Answers
SOURCE: My toshiba satellite laptop won't turn on
There are a number of things that could cause this.
Starting with the simple diagnosis and moving onto more difficult problems:
1.) Check the On / off button is not sticking. If it does not free up after pressing it, the laptop will shut off. cleaning the area with some meths or isopropyl alcohol will help free it (laptop unplugged)
2.) If there is a small cut off switch (located just below the screen where the lid hinges close, see that it is not sticking, this causes the aptop to shut down if the lid is closed.
3.) Next, check to see if it will work plugged into the mains, with the battery removed. If it will, then get the battery checked. Check also that if the battery is fitted, the latches are in the lock position
4.) Check the AC adaptor green led light is not pulsing or flicking, it should be steady green. if is IS flickering, try a universal one. If the problem persists, you may have an internal fault on the motherboard
5.) Check the security of the DC jack, if this is loose or sloppy or feels worn, you need to get the jack replaced (see below), leaving it in this condition can cause arcing and permanent damage to the motherboard
6.) Check the adapters output voltage using a voltmeter, with the red probe on the inner contact and the black probe on the outer contact.
7.) Try swapping out the ram (if accessible) sometimes a ram module goes bad and stops the laptop from switching on, at this stage, disconnect the hard drive and see if it switched on with it removed.
After that, you are almost certainly looking at a strip down of the laptop, depends on whether you feel comfortable doing this..otherwise a repair technician will be needed
Possible causes will be:
A. The DC jack cable from the port to the motherboard is damaged (check continuity with a multimeter set to Ohms)
B. The Power capacitors or diodes on the motherboard are damaged (probably new motherboard needed)
C: The laptop has overheated at some point and the graphics chip has unsoldered, CPU fan failed, or CPU dead.
A good technician will be able to diagnose the fault from a few tests
Posted on Jun 15, 2011
Logicl77
  • 17 Answers
SOURCE: my little buddy won't turn
I have 2 of these devices. Try using a cellular phone charger with the same plug at the end and plug it in. I have waited 5-10 minutes after doing this and they have come back to life and turn on. Maybe it will work for you.
Lewis
Posted on May 14, 2011
Frank Ferree
  • 335 Answers
SOURCE: Replaced stock bcm with used.
A used body control can be used in a vehicle other than the vehicle it was installed in. the body control module when first installed is programmed with the vehicle vin number. the vin number can not be changed was it was written to the BCM. the oprions can be always change in the BCM but not the VIN number. basically the used bcm you have installed has the vin number from the vehicle was installed in, now the vin number in the used BCM doesnt match all the other control modules
Posted on Jun 08, 2011
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: Toshiba Satellite C655-S5082. Won't power
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Posted on Jul 16, 2011
Kris
  • 73 Answers
SOURCE: I have a HP a6300f
The duration and time of the beep codes is going to tell you what the problem is..
Here is the hp page that has the beep code information.
HP Beep Codes
The specific beep code info is towards the bottom.
Hope this helps
Posted on Aug 29, 2011
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Won't turn on
try holding the power button down for 8- 10 seconds... then release. Still not on? Is the unit charged?
Jan 20, 2013 | Sharper Image Literati Reader 16375680042...
My television does this thing now where you can turn it on and 10 seconds later it turns right back off again and when you go to turn it off from the power button it won't let you.
The horizontal output section to your TV has some shorted component/s. Check and replace them. Contact any experienced service technician.
Oct 14, 2012 | RCA TruFlat 27F520T 27" TV
My boostmobile galaxy prevail won't turn on, no lights, no sounds.
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 27, 2012 | Motorola Cell Phones
Lenovo P650WG Phone Won't turn on
5.Wait 10 seconds.
Step
Thanks
Aug 04, 2012 | Cell Phones
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
Won't Boot after pressing the power buttton
Unplug the tower and press power button for 60 seconds, if this fails the motherboard should be suspect, check all plugin connections to the motherboard especially power supply connectors.
Jun 17, 2012 | Dell XPS 8300 Desktop
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    RCA D61W20 61" Rear Projection Television Logo
    Top RCA Televison & Video Experts
    Paul Bade
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
