Question about Samsung Washing Machines
Can we use washing machine after we found a dead rat
Posted by sankar on
Rylee Smith
  • 8,619 Answers
Hi
Thanks for using FixYa. Yes you can use it however, before using it run your washing machine with only two cups of vinegar in it and make sure it is empty & set on its hottest temperature setting so that all the smell is gone. Please revert back for more help.
Rylee
Posted on Dec 24, 2011
1 Related Answer
Anonymous
  • 36 Answers
SOURCE: My front loding washer smells like dead rats! Please Help!!
you will have to take the back cover off your washer. you should be able to find your dead rat there
Posted on May 03, 2009
Panel board wires have been cut by the rats...is
solder and heat shrink or solder and liquid electrical tape
Dec 17, 2009 | LG WM-1832C Front Load Washer
Will not spin on final spin
My GE had same problem. AFter looking on this website, I found out how to clean the filter. You wouldn't believe the rat's nest of stuff I found! Plugged it back up and it spins like a dream now.
Nov 15, 2009 | Kenmore 44102 Front Load Washer
May 03, 2009 | GE WSXH208A Front Load Washer
My washing machine is blacked out even when i swtich on the powear
WHITE WIRES ARE USUALLY NOT HOT. THEY ARE NEUTRAL
Apr 13, 2009 | Washing Machines
Washer
In my case the water pump was not working and checking the wiring I found that the power cables of the water pump had been broken by Rats.
Aug 20, 2008 | Washing Machines
Washer won't stop filling. don't think it is faulty inlet valves. i can't locate any air dome/pressure switch assembly. ge washer model # wwa 8300 balwh
It was actually filling up and flooding the room. Found that a rat had chewed through a hose and repaired the hose inside the washer and it now works fine. Thanks
Jul 12, 2008 | GE Washing Machines
Washing Machines Logo
458 people viewed this question
Top Samsung Washing Machines Experts
Marvin
Marvin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
