The volume signal appears and the volume goes either up or down. How can I fix it?
If your using front button to change channel then try to use remote..
If on the remote is fine then the button board of your TV got faulty usually it cause bad contacts of button (vol+,vol-) so that if you press any button the volume button activated due to auto contact..
You can replace the button or replace new button board assembly..
When I use the HD PVR remote the volume remote of the TV increases or decreases when I scroll the channels
