Question about Sony Handycam CCDTRV118 Camcorder
Hi8 sony camera won't play cassettes
Having trouble playing back cassettes to convert them to DVD's. Has multiple beeps and won't allow it to playback tape.
Posted by amy Bennett on
5 Related Answers
Anonymous
  • 73 Answers
SOURCE: Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Posted on Jul 29, 2007
Anonymous
SOURCE: Message reads eject. won't eject
Ihatecanon, Tried the steps you provided above with no luck. Then decided to gently smack the camera twice on the right-top side of the tape compartment. It freaking worked the first time. Got this idea by watching Eric Cartman on South Park... No, really. I read about this in another forum. It's a quick $150 back in your pocket. Just think. You sent the camera to their tech guys and paid them 150 to SMACK-IT :)
Posted on Sep 29, 2007
Anonymous
SOURCE: cassette loading error 31:23
I have had this same problem several times. In all cases the problem has been a tape that has been run at the very end of it's lenght and it is too tighten. I loose the tape manually just a bit and it helps. Just be careful not to leave the tape too loose.
For loosing the tape you have to push the lock button with e.g. a pen and while doing that just take the tape out just a bit. Tape should be left at the level it was. It must not look like a loosen tape. If you get it out too much, just roll it back by twisting the reel again while pushing the lock button down.
To be able to loose the tape you of course need to open the protective lid first. For this there is a separate lock switch at the side of the cassette.
Posted on Mar 05, 2008
Anonymous
SOURCE: No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Posted on Mar 09, 2008
Anonymous
SOURCE: Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Posted on Jun 21, 2008
Why am I having difficulty rewinding and playing tapes?
Is the Canon UC9 a HI8 camera?? If not it wont play HI*.
Aug 21, 2015 | Canon UC9 Camcorder
I can't play a hi8 cassette recorded in another camera y my camera, what can i do?
DCR-TRV130 is not capable of playing back 8mm or Hi8 tapes recorded on analog camcorders. Digital recording playback only.
Feb 16, 2010 | Sony Handycam DCR-TRV130 Digital Camcorder
Sony handycam video cassette
To the best of my knowledge 8mm VTR's have not been available for some time now. On the other hand there are plenty of Hi8 cameras and players available after market. eBay is a great source. Keep in mind that Hi8 cameras and decks will also play standard 8mm video tapes.
There are also many video tape transfer services that will transfer your 8mm tapes to DVD or other formats of your choice. Just Google "videotape transfer service"
Aug 28, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Oct 23, 2008 | Sony Handycam DCR-TRV140E Digital...
Sony TRV510-playback, audio choppy, image isn't clear
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
I tried it, and IT WORKED!!
Jul 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Hi8 camera tapes
any brand of hi8 or digital8 camcorder will play back those tapes but sony made a tape deck made to record and play back digital8, hi8, and 8mm tape. you can get here http://www.sonystyle.com/webapp/wcs/stores/servlet/SearchCatalog
Feb 12, 2008 | Sony Hi8 Hi-8 Tape
Play back problem
Your camera playback heads appear to be dirty. You can purchase a head cleaner cassette from an electronics store or take it to a service centre where they will clean the heads.
Check that the tape itself is not damaged, as this can cause the same symptoms.
Jan 03, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Dec 06, 2007 | Video Cameras
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony Handycam CCDTRV118 Camcorder Logo
Top Sony Video Cameras Experts
Jax Planet
Jax Planet
Nasir Muhammad
Nasir Muhammad
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
