Hi i have a UX-GP5 that will not charge the ipod i have traced the wires back and tested all the pcb boards and found there is no power on a couple of the leeds joints from the main power pcb board. there is a problem with the power supply so to speak so i was woundering if this may of been a problem with these units as i cant seem to pin point which component it is in the power supply board i do know the power ic is geting red hot iv resolderd this but it is still the same kind regards andrew
Put a golf ball behind your Ipod, this will push the connections down. I had the same problem after 4 years of use and the golf ball has been working great for the past 5 years.
SOURCE: my JVC UX-GP5 docking station no longer charges
Unfortunately the UX-GP5 has a flimsy ipod connector. The connector is soldered to a small circuit board in the flip-down dock. After repeated use the connector wiggles and breaks free from the board. Various symptoms result depending on how many connections break. A replacement board is available from JVC in the US. The part number is GVA10161-A1. If you're tecnically proficient you can change it yourself by opening the cover on the docking door. It's held in place by two screws that are hidden under a glued metal strip at the back of the door (behind the ipod connector). Once you get that open it's a simple matter to unscrew and unplug the defective board.
