Question about Activision Call of Duty Modern Warfare 2
I have the statu code 30-80-00 how do i fix this
Whenever i put it init says open tray then reading then open tray and there are no scratches on the disc help!!!
Posted by conor boyd on
Status code 30-80-00
Status Code 30-80-00 is usually an issue with your game disc, not your XBox. That is the good news.
Some XBox games are protected regionally. For example, if you buy a game in the United States and try to play it on a system that was purchased in Russia, the game will not work. Sometimes it won't read the disc (like it did for you), other times it will freeze up in-game.
I am not sure what your purchase history is, but if you purchased either the game or system online this is probably the issue.
Another potential issue is the disc just being faulty. It may not be scratched, but it could be defected in some other way.
My advice is to return the game disc, explain the problem, and get a new copy. Most retailers will accommodate you if you are polite. If they will not process the request, raise a fuss and call customer service.
Dec 23, 2011 | Microsoft Xbox 360 Console
XBOX 360 "Open Tray " message
Your CD/DVD drive has failed mechanically. Usually this is a physical problem where the disc is simply no longer in alignment with the laser. It does not necessarily mean something will make noise, and can be just one small part slightly bent or broken so the disk now moves freely top to bottom.
If you can do a warranty repair, you're set. But if you are no longer under warranty, you only have two options. you can try and replace the drive, which although odd shaped; I think is just a standard IDE drive, or you can shift the XBOX 90 degrees to Re-orient the box. In some cases this may let gravity hold in place what the internal mechanisms no longer are.
Mar 15, 2010 | Microsoft Xbox 360 Console
Turned it on and put in a disc and it says reading disc and then it says open tray
the disk is scratched or the lens is dusty. if scratched get it refaced. or lens open tray and use a can of air to blow it off.
Dec 27, 2009 | Microsoft Xbox 360 Console
Insert game and it just says open tray
either the disc is ultimately scratched or your drive is malfunctioning.
To fix mine i just bang the xbox on the top and turn it off and back on.
Sep 27, 2009 | Microsoft Xbox 360 Console
My Xbox 360 wont read any games, CD's or DVD's
Its the Disk Drive, its not able to read it because something got in there and scratched the reader, or its just old and broke. but a new disk drive will fix the problem.
Aug 15, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at [email protected] ty
May 29, 2009 | Microsoft Xbox 360 Console
the lens of the disc drive needs a check up...
Keeps telling me to open the tray whenever I put a game into it..not reading any disk
you re going to need a new disk drive i had the same problem and called 18004myxox and they said its a bad disk drive and would cost 100.00 to fix so i went and bought a new 360 insteadf
Apr 17, 2009 | Microsoft Xbox 360 Arcade
Xbox 360 load disc, goes back to 'open tray'...
repairs sound good dude or the disk is scratched!!!!!!!! Clean It !!!!!!!
Oct 16, 2008 | Microsoft Xbox 360 Console
Activision Call of Duty Modern Warfare 2 Logo
Top Activision Video Game Consoles & Games Experts
ray gallant
Tom Chichester
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
