Question about Polaroid Televison & Video
My 40 inch Polaroid LCD tv screen won't come on
Posted by ckenney25 on
Rylee Smith
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight and/or an inverter board issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. The cost to change the inverter board including labor would be around $250, if you get this done by a professional. Please revert back for more help.
Rylee
Posted on Dec 23, 2011
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: hdtv lcd 40 in. broken screen face
There is no glass or plastic screen infront of the LCD panel.
If the screen is damaged you will need to replaced the entire LCD panel.
Posted on Dec 15, 2007
Anonymous
SOURCE: 40 inch lcd blue line vertical
Have just purchased Samsung LA32R81BD have thin blue vertical line a third into the left hand side of the screen. A pity no support on a sunday or public holiday! Tried the squeeze theory without joy. Will attempt swap and see what excuses the dealer has? Thanx for advice fixya!
Posted on May 03, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Polaroid TDA-03211C Combination 32 inch, LCD-TV/DVD *1080i/720p*
Check required Codes for TV Here for DishNetwork remote.
Posted on Oct 03, 2008
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: i have a sony 40 inches bravia flat screen hd and
Could be the decoder:
1. unplug the TV ans wait a few mins.
2. If you have digital cable box or dish tuner reboot those as well (likely your issue)
What you have is artifacting what that means is tiling garbiling and freezing this happends when the data in the digital stream just stopped hence Frozen.
Try those things rule out your cable tv box first or your sat box, if this is OTA over the air your antenna.
1. Try DVD's if it happends during a DVD you do have a decoder issue if it does not you need to talk to your cable tv or sat operator.
So you got 3 possiabilites here 1. the worse Decoder, 2 cable company or satalite provider, 3 your antenna is in the wroung position.
I sure this will help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Nov 30, 2009
Testimonial: "i just hope this works"
Chi Chu
  • 8457 Answers
SOURCE: polaroid tv goes immediately off after turning on
Ur tv power supply board is defective.That the board where the a/c power cord go into it.Replaced the power supply board,ur tv will have stable power and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on May 27, 2010
Testimonial: "thank you so much. also thanks for the tip on where to buy it. i cant wait to repair it myself. i'll let you know how it goes."
40 inch polaroid lcd tv
This is a common problem with Polaroid sets. I would check the power supply/inverter board for any capacitors with bulging tops. The typical ones that cause this problem are 10uf 450V caps.
May 07, 2013 | Polaroid TLA-04011C 40 in. LCD TV
WHAT VIDEO FILE PLAY'S VIA THE USB
tried with other files doesn't work like mpeg4, divx and jpeg?
Oct 27, 2012 | Polaroid TLA-04011C 40 in. LCD TV
I have a 37 inches polaroid tv and, it was working fine at night, in the morning when I turn it on, a a black spot show on the right side of the screen
Depending which model, this tv may have an inverter master and slave module set. I find best to replace as a pair. These modules feed the flourescent lamps that backlight you lcd screen. more than likely the one failing is on the same side as the spot you are seeing. I always first look at the power supply panel, to be certain that capacitors on this board have not failed or leaked out.
Parts look here http://www.shopjimmy.com/tvs
Jul 09, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid TLA-04011c 40 inch. LCD TV? How can u fix TV plasma screen? my friends kids hit the tv screen for with wii remote. i think they broke the tv screen from the one side. and how much it cost to fix...
Sorry this tv can't be fix acept replaced the whloe picture screen panel itself,the tvs screen panels are in of the limited production by the tvs industries,only can buy picture screen panel from the tvs themselves and it 90% important to the tv,will cost u the same as a new tv to get picture screen replaced.Sorry doesn't worth as a whole tv anymorre the tv now only worth as salvages tv for it electronic boards for spare parts for other tv,that it.
Dec 19, 2010 | Polaroid TLA-04011C 40 in. LCD TV
40 inch LCD tv
Check your settig menu, it should give you options. OR try loking in instruction manual.
REMEMBER the large majority of TV programmes are NOT HD right now so mpstly you are not missing anything,
Feb 12, 2010 | Polaroid TLA-04011C 40 in. LCD TV
I need to know if my new Wii system can be set up on my new Polaroid Television without harming to television.,
Hi
Just try not to leave the game on standby with the same picture on for more than 30 minutes. As long as there is movement on the screen there won`t be any" burn in".
Hope this help. Merry Christmas
Dec 17, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Televison & Video Logo
505 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
