Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
3 times flash of standby light shows that Lamp Cover is not mounted properly after replacement of Lamp. Please fix lamp cover properly because cover has to press protection switch in circuit.
Doulbe check in the owner's manual, but this is usually an indication of a bad lamp or fan error. There will be a table in the owner's manual listing the error codes as shown by these lights. I can't give you more details without the exact model number.
