Car Audio & Video Logo
Question about Alpine Car Audio & Video
Cda-9807 owners manual - Alpine Car Audio & Video
Posted by russell on
Govindaraj.N
    New Friend:
  • 36 Answers
Goto the below link http://www.alpine-usa.com/
and goto Tech Center/archived manuals
Posted on Dec 22, 2011
Alpine cda 9807 in yukon xl
hi david, check out the connection of the yellow and red wires on the back plug. yellow must be connected to a direct battery positive line(continuous positive), the red must be connected to a live wire from the ignition switch OR from a point that is +12v live once the car is started(switched positive). also make sure that that the ground connection is a direct good connection to the body of the vehicle!! make sure that the remote wire(blue) is insulated if you not using an automatic aerial or external amplfier. good luck.cheers.
1helpful
Time set
Hello
Try to download its user manual from any one among the folloing links. It will have all details.
http://www.pdfjungle.com/alpine-owners-manual-cda-7998-for-alpine-cda-7998-cd-player/alpine-owners-manual-cda-7998-for-alpine-cda-7998-cd-player-pdf-preview/
http://www.dataentryjobs.us/67948.html
http://www.retrevo.com/support/Alpine-CDA-7998-Car-Receivers-manual/id/23223dj397/t/2/
If you feel any difficulty in downloading the manual, inform me by Fixya comment, along with your email address. I'll send a copy of the manual to your device by return mail.
I have a CDA hob with the following ref CD661/1ss p58 model ev6300 and I need an owners manual and fitting instructions I also have a CDA. Microwave oven with ref c93cs51v. Vm1ss and need owners manual...
Lynn, I have a CDA VM1SS combi oven. I can email you a scan of the users handbook. It runs to 11 A4 pages, so I won't clog up this site by posting it here.
Bryan bryanlockey at hotmail dot com
Where can i get the code to use this as i have just installed it in my new car?
there is no code for that radio. what exactly is the problem with it? if it is not turning on, make sure you are getting power to both the red and yellow wires. red is switched (ignition) and yellow is constant.
3helpful
HOW TO SET THE TIME ON ALPINE 9807
Hello! In clock priority mode...Press and hold the Disp/Title button for 3 seconds, The time indicator will blink...Turn the Rotary/Encoder to adjust the hour...When hour is set, turn the Rotary/Encoder to adjust the minutes...Time is set for 5 seconds after the minute...
Guru............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
The cd player just stopped in the middle of a
try either pressing the reset switch (if there is one) or disconnecting power to the deck.
5answers
Alpine cda-9807 no voice when cd plays.
hi
Try to set the cd function to settings! or menu, maybe you have not fair settings in your unit!
Thanks!
I dont have a colour code for the wiring
Red is ignition
Yellow is constant hot
Black is ground
Gray wires are front right
White wires are front left
Green wires are rear right
Purple wires are rear left
Blue is power Ant if equipped
Orange is ilumm
Make sure you use the proper wiring harness for your vechile.
Hope this helps
2answers
Instaling alpine car/cd stereo cda 9807
Its probably your wiring harness that came with the stereo. Which can cause many more problems. alpine changed their wiring harness around that time. But they used the same plug, just wired different. So now there are crossed wires, but the plug fits, causing the amp chip to fry. maybe even further than the amp chip. an amp chip replacement runs about 80$ at a repair shop. if its just that.
A.M. stations
What type of vehicle is it in? Some manufacturers, such as Toyota, use separate antenna plugs for AM and FM that cannot be plugged into an aftermarket unit at the same time.
Open Questions:
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
