My initial thought was that it was a paper feeding issue since it won't feed paper either but when I opened the cover to clean the area out, I noticed that the ink cartridges wouldn't move to the center like they usually do. Then I noticed that the sound I was hearing seems to be coming from the area around the "home" position of the ink cartridge caddy. I can't see in that area so I'm not sure if that is where the problem is.
Symptom look like carriage jammed in service station,open cover gently try to pull carriage out if its jammed, open top & side covers, release service station capping through manually rotate gears, once its released, push carriage left side, remove service station & verify why its jammed, if found any breakage replace it, or clean it..but little bit technical skill required..see the similar diagram below:
