I inherited the machine but no manual came with it.
SOURCE: I need to know how
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
all machines thread the same. TTN tension, take up,
needle.
Beginning with the spool, guide the
thread through the thread guides to the tension assembly. Pull the thread
through the tension assembly and test it to make sure the tension is working
correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way.( If you load your bobbin
case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT.
There are some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
sewman7
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
SOURCE: How do I thread my necchi Lydia type 544 sewing machine
Threading guide - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_542_544_threading_Diagram.htm
Make sure the presser foot is up when threading any sewing machine.
SOURCE: I need a manual for a Necchi Royal Series,
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
