Question about Panasonic RR-830 Desktop Cassette Transcriber / Recorder
My transcriber has started turning itself off.
At random times, the power button will just shut itself off. Everything else seems to be working fine. What is causing this?
Posted by Bev Hackworth on
Javier Gonzalez
  • 207 Answers
Hello your unit needs service and is probably need to replace internal power switch you may take advantage of after Christmas 50% Off Service Rates Special it is only from Monday Dec. 26th thru Friday Dec. 30th 2011 only. At http://www.tvps.com/Products/One-Service-Unit-for-AnalogDigital-DesktopPortable-DictationTranscription-Machine__ECS-ADDPS.aspx
Posted on Dec 24, 2011
My machine's screen keeps turning off but the function buttons stay lit. The machine appears to reset itself randomly while im sewing and sometimes even when im not near it. Everything else seems to be...
Has your Designer 1 ever had the power supply replaced? Almost all Des 1's had a recall that was replacement of the power supply. Any Husqvarna Viking dealer will be able to check the power supply, or transformer, in your machine and make sure that it has been replaced. Sometimes this can be a loose connection inside the power supply.
Sep 17, 2011 | Husqvarna Designer I
Randomly switching off and coming back on by itself.
power supply board may be failing or the power button may be sticking. If it is a Samsung, it is the power supply.
Nov 17, 2009 | Televison & Video
Nokia N73 music edition power (on/off) button seems hanged
sir plz hard reset your phone hard reseting code is *#7780#
Sep 03, 2009 | Nokia N73 Cellular Phone
Off button doesen't shut off oven
You will probably have to replace the electronic range control.
Jan 03, 2009 | KitchenAid KESC307 Electric Kitchen Range
Instantaneous shutdown of my Toshiba Satallite A105 Laptop
Hi Sam,
What operating system are you using ?
If you remember what time it last randomly shut down on you, use the system event viewer to see what errors were given just before it turned itself off. You can access the event viewer in Windows XP by clicking on the Start button, then click on Run, and in the box that pops up type in "eventvwr" and hit enter.
Click on system on the left hand side to view the log files of the system. Browse down until you find the time when your laptop turned off. Hopefully there is a series of errors there. They should be able to tell you something about why it is doing it.
Hope this helps, feel free to post some of the errors back here if you find any!
David
Nov 19, 2008 | Toshiba Satellite A105 Notebook
Electrolux Renaissance power nozzle turning on and off, brass pins hot
The deal with the Renny is that it runs off of circuit boards. Usually the problem of the main motor shutting on and off is caused by one of the Triac boards located inside the canister. Another problem could be the thermostat wire located on the inside of your motor itself. It's almost never the thermostat, so the triac board is most likely the issue.
As far as your power nozzle goes, the head eminating from the swivel body is in most cases due to an older design of the power nozzle. I would suggest investing in a new elbow assembly that includes a new swivel body as well as newer style of wiring that is proved to reduce arcing and heat production within the power nozzle.
In some cases, fixing the power nozzle will fix the problems you are experienceing with the main motor as the arcing happening in the power nozzle can in fact turn off your machine. So investing in a new elbow assembly for your power nozzle could in fact solve the problem in its entirety.
Oct 26, 2008 | Electrolux Guardian Bagged Canister Vacuum
High pitch sqealing noise
This is caused be a bad record switch. As a temporary solution, incert a blank tape, push the record switch, then stop. Repeat about 10 times. This may clean the contacts of the record/Play switch but it will probably need to be replaced.
May 20, 2008 | Panasonic RR-830 Desktop Cassette...
Turns Off by itself
Causes for this problem can be any of the following:
1- CPU gets overheated. solution: clean dust from fan and heatsink assembly and donot forget to replace the heatsink compound, this is very important.
2- Memory problems. solution: use a program called MEMTEST86+ from the site http://www.memtest.org/ . It is a free and great program.
3-Power problem. By time the capacitors of the power supply gets dried. Causing them to not be able to fulfill power demands. solution: try working with power supply without battery. As the power supply has to run computer and charge battery. We reduce the load. If everything is fine. repair power supply by replacing deffective capacitor.
4-Battery problem. Try operation without battery.
5-Dried solders on motherboard or a component problem on the motherboard. Solution: no solution except replacing motherboard.
Eng. A. Jarabaa
Aug 28, 2007 | HP nx9110 Notebook
Panasonic RR-830 Desktop Cassette Transcriber / Recorder Logo
91 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
