Question about Sony ICF-SW77 AM/FM/SW Radio
The sound on AM channel is very poor while that on FM is excellent.What is the cause of this problem ?
I enjoy listening to SW station but the problem with the Radio is that you must use either ear phone or put the radio close to you ear to listen to stations on AM/SW channels.
Posted by salmanun zazzau on
Rod Wallberg
  • 494 Answers
Usual problem can be traced back to faulty electrolytic capacitors, solution is to replace all capacitors and make sure any leakage is cleaned up with needed repairs. Contact me if you need help.... poikaa(at)yahoo(dot)com
Posted on Feb 06, 2012
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
On AM radio, there is often a sound, like a hammer hitting a 55 gal. drum interrupting the program. Does not do it on portable radio carried in the car.
all stations AM?
is the engine running?
for get the portable, some have vastly better a/m radios than any car has. in fact many cars radios a/m OR of horrid quality.
i can tell you why but its boring. (AGC, read up on that)
did you try the radio in car, parked say across town.?
did you try all stations
are you like 1 block away from an AM radio station, overloading yours.
AM radios are basically noise making radios., that is why FM was invented to stop that noise, (i cant hear it so.........?????)
are you listening to far away stations, this is normal
in fact you might hear 2 stations on same channel (freq)
and they will beat against each other.
on case of is in S.Calif where your station is clobbered by high power mexican stations 50,000 watts. strong.
and worse a night, does it get better in the day?
here is my advice, many AM stations have a rebroadcast on FM.
go there and listen. (use SAT radio?)
AM radio is subject to vast sources of noise.
ignition noise., high voltage power transmission line noise.
machinery noises, (electric)
or even illegal transmitters in your hood.
many new cars the AM radio is junk, they use this very cheap
chip inside that does this very poorly, but allows them to say
it has AM. ( for $1 cost)
the FM side is 10x better, or more. move up to FM like we all did back in 1967. (i used to build and sell converters back then)
answering for , all other modes work perfect, but AM radio..
Tune stations on the radio
Use this link to see how to set up and listen to AM/FM stations.
How to listen to FM and AM broadcasts
1helpful
Poor radio reception in 2008 toyota avalon
I had the same exact problem. Toyota changed the Amolifier that improved sound quality but not the FM Reception.
THE HARNESSES CONNECTING ANTENNA TO RECEIVER (TWO OF THEM) HAD IAASUES. REPACING THEM FIXD THE ISSUE. FM RECEPTION EXCELLENT NOW !!!!!!!
2helpful
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
I have an older onkyo integra (TX-870) which pop when I change stations, then no sound. Need to turn off and begin again. Can this be fixed or should I purchase a new 2 channel sys?
Hi, It sounds like you are listening F.M. radio and the F.M. muting button is engaged ( as well it should be-otherwise you will have static between the stations ) sometimes there is almost a "THUMP" sound when you switch stations-this is caused by the receivers P.L.L. circuitry losing then locking in on stations, if you do not lower the system volume you will amost assuredly cause an overload of your final drivers, that's why it will come back on when turned off-it has reset. Turning off fm muting will get rid of the "POPPING" noise-it will however leave you with unbearable static which in turn should cause you to lower volume momentarily eliminating the need to constantly turn off the receiver. Thank for asking FixYa, I hope this helps, let me know how I did or if I can be of more assistance, good luck Prodzilla
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Poor cound quality
does the XM use a radio station for recieving the sound or is it wired in to the vehicle. if you have to set a radio station so you can use the XM then what you can do it set the station to some other channel. it maybe to close to a real radio station or the frequency it to weak and you'll need a stronger signal
Degen DE1103 background tone
the background tone is due to frequency static...the design of the stereo is not good... it lack of noise destortion cirquit..and almost all stereo that is analog usually poor in in design..change the stereo.try stereo that is digital in design..
Poor FM reception
The Phone must be on.
The SIM card must be a valid one.
The station you listen to and the network operator you use, must support the service.
The headset or enhancement needs to be attached to your phone. for the FM radio to function properly, it's an aerial as well as a headset.
Therefor if you are in a poor reception area for making/receiving calls it will also affect the radio signal.
Sony ICF-SW77 AM/FM/SW Radio Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
