Moultrie M80 Game Spy Digital Hunting Trail Camera Logo
Paul Shuler Posted on Dec 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error card shows on screen - Moultrie M80 Game Spy Digital Hunting Trail Camera
Ronald Lockhart
Level 2:
  • Moultrie Expert 296 Answers
  • Posted on Dec 23, 2011
Ronald Lockhart
Moultrie Expert
Level 2:
Answers
296
Questions
0
Helped
123905
Points
644
Go to www.moultriefeeders.com...under mini cameras find the M80...open "full details"...scroll to bottom and find manuals/downloads...where it says upgrade click and download to your pc...be sure you download for your camera as Moultrie named all their camera downloads the same, but each is model specific...it will download as a compressed file.I use windows to extract file directly to NEW SD card installed in my PC's card reader slot.If your computer doesn't have a card reader, connect one thru a USB port.
Once you have upgrade unzipped to the sd card, put card into the M80 and switch the camera to the "aim" position....should show "upgrade NO"..press up/down key to change to "yes"; press enter and wait...DO NOT TURN OFF CAMERA AND USE NEW BATTERIES...camera will turn itself off when done.Power on camera and test it out.This has solve the trail err and a few other issues with the M80.
2helpful
SD error show on the screen
SD card it the memory card you should insert. Fine a not to expensive on on the net, and order one.
7helpful
'memory card error - card locked!'
pull the card out
find the slide button on the side and slide it to the "unlock" position
put card back in
enjoi
2helpful
"format error" message
Reinsert memory card in camera and try to format it. If that does not help then check with new memory card as old memory card could be defective.
Thanks.
3helpful
Why does it say memory card error on the screen
Hi there, For few reason camera showing memory card error.
1. Memory card damaged.
2. your memory card finished is life time storage memory.
3 . virus infected.
4. If your memory card storage capacity more than camera support card then its also show to you. For example your camera support maximum 2 GB card, but your try to use more than 2 GB memory card.
I suggest your remove the memory card and scan by updated antivirus. After that, if not working then fomat it and try.
Thanks & waiting for your feedback.
Memory card error shows on screen.
meory card error can be cleared by for4mating the card ocne in the camera itself. use a low level format
Card error
it is not the camra but the card . Was down loading photos on to computer , started ok
then stopped and screen reverted to stand by
Put card in camra and showed CARD ERROR. Been told could be faulty card .
bryan87
Aug 21, 2008 • Cameras
2answers
Card error -Revolt 500 Olympus
i have the same problem out of no wheres the lcd screens says card error ive been formatting allmy cards for the past 2 days & no luck whatso ever! its brutal im lost with out my camera any solutions???
ive even tried new cards that werent used before!
2answers
Memory Card Error
Do not ever format a card.,any card via a computer That does it in. For camera use it will not be recognised. Put the card in the card reader and if there is anything at all on it delete it. Try to reformat in the camera again- failing that -new card.
2answers
The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Top Moultrie Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Moultrie Home Security Expert? Answer questions, earn points and help others
