When i try to write a dvd on either a dvd +r or dvd+ or + rw dvd--and have tried various brands of these disk but still get error when writing in click to dvd, nero, and other dvd programs. windows xp doesnt even recognize empty dvd media and when inserted, the drive listing changes from dvd to cd.
You could try this tool for resetting your DVD-Rom. If this does not work then it could be you need a new Optical burner.
ClickMe
SOURCE: toshiba dvd rom sd r6012 isn't reading the DVDs
Try some factory CD and DVDs and just try to get them to open in Windows (not play in a media player program). If you get errors on every disc you try, it may be your CD/DVD hardware packing in.
If it reads some CDs or DVDs and not others, particularly media discs, you may be having software driver problems, otherwise, it is likely hardware.
Try inserting the disc and spinning it up while resting the laptop on its side, or even upside down. If it reads sideways or upside down, the CD/DVD reader hardware has gone and cannot probably be prepared (this is a symptom of physical controller failure and is ot fixable by normal means).
Good luck...
SOURCE: disk drive malfunction(cant read or write disk)
i fu got help from me by my solution in other problem pls rate me FIXYA if u like
SOURCE: DVD-RW of Sony vaio VGN-CR590 don't still run after changing win7
About the link you need to download the driver for your DVD-RW drive, have you tried the Pioneer website?
SOURCE: sony webcam no longer works with windows 7
1. The drivers for this Web camera may not be developed for Windows 7 64 bit by the manufacturer.
You will either have to purchase a new camera to be compatible with Windows 7 or Vista 64.
This is also true for your SD card reader.
does it recognize a blank cd
