Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch nexxt essence won't spin
It won't spin, sometimes stops mid-cycle and just quits. it can tumble, but doesn't always. sometimes i can get it to spin if i set it on the spin cycle on reduced spin, but not always. sometimes i'll try 7 times, and then give up wait and two hours later is will partially wash and then stop again mid-cycle. what could be the problem?
Posted by julia on
bernard miller
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 121 Answers
Either a blocked filter or worn carbon brushes
Posted on Oct 11, 2017
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: Washer doesn't complete cycles
Sounds like an electronics problem. Get a Bosch repair person to look at it. Hopefully, they can reset the computer inside. Otherwise, it's a part that costs more than $200, as I recall, plus too much to do the work. Bosch's 1-800 person once advised me to unplug my washer - a model 2401 - for a half-hour as a way to reset the electronics. You might try that. Pray to the appliance gods. Maybe your machine is still under warranty. Trouble is, you'll probably have to wait for days until an authorized, over-priced repair person comes to visit. Bosch is way behind in service levels here in the U.S. They know it, but it's not worth their time or money to fix, it seems. A long story ....
Posted on Sep 20, 2007
Anonymous
  • 213 Answers
SOURCE: Bosch Nexxt Essence Washer
start a cycle, once the door lock light comes on pull on the door to see if its really locked if not, you need a new door lock assembly
Posted on Nov 20, 2007
Anonymous
SOURCE: My Bosch Nexxt Essence front
My Bosch Nexxt Essence front load washer will not drain. I changed the lint filter, and insured that the drainage hose was free of debris. I removed all the wet clothes, wrung out the excess water, and redistributed the clothes. Still, no draining or spinning. Initially there was a humming sound, but now there is no sound at all when I try to restart the drain or spin cycles. All the lights are appropriately "on".
Posted on May 24, 2008
adrian halligan
  • 1075 Answers
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Posted on Jun 29, 2010
Jacques De Meyer
  • 500 Answers
SOURCE: Hi our Bosch exxcel washing
Hi gillsteer,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Posted on Jul 18, 2011
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
Aug 31, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
My Bosch Nexxt Essence front load washer is making a knocking and squeaking noise during the whole spin cycle. It sounds like it's coming from the drum mounts - what should we do?
Apr 13, 2008 | Bosch Washing Machines
Bosch Nexxt 700 spin problems
yes it could be normal if the balance control senses that the load is uneven however the same problem could be caused by a blocked filter or blocked sump hose.
Dec 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Dec 21, 2007 | Washing Machines
Nov 12, 2007 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
350 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
