Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
I suspect the element in the water heater is either burning out or shorting to earth. If it's burning out, the increased resistance will cause an overload and trip the breaker or blow the fuse for that circuit. If it's shorting to earth, it may trip both the breaker and the RCD in your fuse box / consumer unit.
Next time it happens, check whether the RCD switch (assuming you have one) is in the 'OFF' position. Most breaker boxes will be fitted with an RCD which protects many, or all, of the individual circuits. It's easily identified by the presence of a 'TEST' button.
That's only going to be a clue to the likely cause of the fault though. You really need to do some testing of the element with an ammeter and/or multi-meter, if you have one. I can provide instructions for testing if you have the equipment and inclination.
Unfortunately, if it is the water heater, the cost of a replacement is about £100 for the part alone, for the SGS43C12. Water heaters for most other Bosch models are roughly the same price and some of the older models can be £130+. If you need to get someone in to fit it, you could be looking at a total bill of between £150-200. Considering the age of the SGS43C12 / Classixx, it may be time to consider replacing the dishwasher.
Obviously, I'm assuming it's the water heater as this is the most likely cause, but there are other possible faults. If you need any instructions on testing, etc, please confirm the correct model number as the SGS43C12 isn't a slimline model.
Hope this helps. Please let me know if I can be of further assistance.
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
