My PS3 was stolen with the dongle still in the USB port. I'm trying to figure if and where I can get just the dongle. I still have the gun and sensor. I do not want to buy the entire package just for the dongle.
This works: Turn ps3 on. Plug the controller into the usb cable and into ps3. Then plug the dongle into other usb port. After a short time the dongle will flash quickly (this means it's in pairing mode - when the dongle flashes slowly it's too late). Press the PS/Home button as soon as you see the dongle fast flashing. All the LED's on the controller will begin to flash and after a short time one (or two) will remain solid. Immediately disconnect the charging usb lead from the controller and again the LED's will flash, push the PS/Home button again and after a short time one or two will remain solid. The controller should now be working. If the controller fails to respond repeat this process but make sure that you disconnect the dongle and reinsert (so you can see the fast flashing lights and try again).
Plug the dongle in to the USB port, turn on the PS3 and the LED will flash a lot (as if you've pressed the connect button), then press L3 and SELECT together for 3 seconds; it'll then connect.
Then press the PS button.
As long as you keep the dongle plugged in, the controller will not disconnect and won't need pairing again.
The flashing lights on the controller mean the guitar is not connecting to the wireless usb dongle connected to the PS3.
1. Verify that the wireless box is plugged in firmly to the usb port on the front of the PS3.
2. If that doesn't work, look on the wireless usb dongle for the guitar hero guitar controller. (It should be a black box with the guitar hero logo on it. You will find a small push button on the dongle. (Make sure your PS3 is turned on, though your guitar hero game does not have to be open. It may be a good idea to have the game running, so you can test your guitar or make sure it is really working). Press and hold the button on the wireless usb dongle for a few seconds. Five seconds should be enough. Doing this attempts to re-connect the dongle and the controller. You will know when the connection is good when the red lights on the controller go steady, as well as the LED on the small button you pressed on the wireless usb dongle. If either lights continue to blink, there is a connection problem still.
3. Try changing the batteries in the guitar controller. Weak batteries tend to cause connection issues.
4. Test the wireless usb dongle and controller with another PS3. This will rule out an issue with your PS3 system.
5. If the problem still occurs on another PS3, the wireless dongle may have gone bad. (This does happen rarely.) Replacements are cheap to find on ebay
you need to be back further maybe for that large of a screen size try re sincing your topshot and the usb plug in and set your dead space to as large as it will go work for me on my 55 in hatachi
1. Turn off the PS3 system.
2. Make sure the gun and the sensor bar both have batteries in them, and the sensor bar is placed either above or below the TV.
3. Remove the USB connector from the end of the stock.
4. Turn on the sensor bar.
5. Connect the USB connector to the PS3 system.
6. Turn on the PS3 system.
7. Press the PS3 button on the gun.
8. Press the Connect button on the end of the USB connector.
9. Press the PS3 button on the Gun again.
10. Gun must be pointed at the sensor bar to pick it up.
