Braun Series 7 790cc Pulsonic Electronic Shaver Logo
Juan Diaz Posted on Dec 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Braun dosent charge - Braun Series 7 790cc Pulsonic Electronic Shaver
Joseph Hoffmann
Level 3:
President:
  • Master 1,756 Answers
  • Posted on Dec 21, 2011
Joseph Hoffmann
Master
Level 3:
President:
Answers
1756
Questions
Helped
409189
Points
4988
Hi, Replace the battery it is faulty. After many charges the battery will not charge any more its called internal discharge Repace it and you are good to go.
I mistakenly connected a two prong nose trimmer plug to my Braun S5. I don't recall if there was a noticeable reaction. But I do know that my S5 will not accept a charge.
Models numbers are useful in such questions but it looks like one might be 12 volts and the other 6 volts.
https://www.google.com/search?q=braun+nose+trimmer+power+cord
Braun Shaver Charger - Amazon.ca
https://www.amazon.ca > braun-shaver-charger > k=bra...
Results 1 - 48 of 602 - BENSN Shaver Charger 12V Power Cord for Braun Shaver Series 9 8 7 5 3 1, Trimmer Electric Razor Charging Cord for 3010s 3040s 3350cc-4 340S ...
Just got a brand new Braun BT5065. I plugged it in to charge, no green light indicating it's charging.
Lot of complaints about this piece of junk. Lot of charging issues like your having.
Take it back and demand your money back.
Check out yhe reviews on the Braun website. As low marks as you can get.
https://us.braun.com/en-us/beard-trimmer-bt3020/reviews
1helpful
2answers
How to fix a Braun series 7 razor that will not charge in cleaning stand
I have a Braun 7 series that I use occasionally. The last time I tried to charge was unsuccessful. After several days on the charger still would not charge, I discovered the RESET button right under the Braun name. The charger cable has to be unplugged, then press reset with a paper clip and now works like a charm. Note: reset will not work if charger cable is plugged in.
Braun series 3 390cc will not charge It has a
You state that is works here so other than the charging not showing I don't see a real problem here. If it drains totally and then does not recharge it is one of two things. Bad battery or bad charger. Replace the charging station first.
When I charge my Braun it does not charge.But sometimes it charge. I do not know what to do
i have series 3 wet and dry braun shaver when it ison charge it only sends ared light to show on grip never it blue charge what is possibly wrong
My Braun 7526 will no longer clip into the razor for cleaning and charging.
If the arm on the charging stand no longer locks down into place to charge the shaver, you will need to replace the arm or you can replace the entire charging unit. You will find both items at shaveroutlet.com. See links below<br /> <br /> arm only<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html</a><br /> <br /> <br /> complete base<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html</a>
Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
Braun 5785 does not charge or auto clean via docking unit ?
HOW TO REFILL BRAUN  SELF CLEAN WITH JUST THE RIGHT BREW. THE MISSING INGREDIENT BRAUN DOES NOT WANT YOU TO KNOW
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ZJ Limited
ZJ Limited
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
