Washing Machines Logo
jax morris Posted on Dec 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zwf1621w. stopped at spin, shows an open padlock
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Feb 02, 2012
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5036584
Points
35540
It appears your lid switch/door latch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
Thanks!
My hoover washing machine stopped working but is displaying padlock symbol but the padlock isn't locked correctly and it's not opened as well
The padlock symbol on your Hoover washing machine indicates that the child lock feature is activated. This feature is designed to prevent children from accidentally starting the machine or changing the cycle during operation. If the padlock symbol is displayed but the padlock is not locked, it's possible that there's a malfunction with the child lock system.
To resolve this issue, try pressing and holding the "Start/Pause" button for several seconds until the padlock symbol disappears. If this doesn't work, try unplugging the machine from the power source for a few minutes and then plugging it back in. This may reset the machine and allow you to deactivate the child lock.
If neither of these solutions work, consult the user manual or contact Hoover customer service for further assistance.
The lock symbol is showing but the door can open and no functions on the oven will work apart from the clock
This is the keypad lock (symbol looks like a padlock?). Find the button that has a padlock symbol near it, hold down for 3 seconds, should unlock your keypad. This should be described in your user manual if not indicated on the touchpad.
Aug 28, 2015 • Ovens
I have a 2002 suzuki liana what does the warning symbol which shows a car with a padlock on three left side of it. Was driving on motorway car judder ed and lost power and stopped struggled to start it...
open glove box, read operators guide, see true name for that
warning lamp, icon, my guess, is IMMO, does car
have IMMObilizer option? if yes, and its light is on, then THAT
is the cause.
the padlock warnings. vary by country. (laws)
so engine is now stalled?
say stalled, 0 zero RPM of engine is stalled
and will not restart and run, correct?
and the pad lock is still on,,
correct?
if yes, then try the other key FOB< that came with car, (by its self)
does this cure the problem. with IMMO.?
never have just one key or this is the results. (will happen)
why not post a photo of the lamp, so helpers dont need to guess.
and country, the lamps are differently marked in different countries, or are USA marked.
no country stated.
ours is called Aerio, In USA, where is yours.?
no country no joy!
but regardless of that, the operators guide is clear, lost that. ?
I ve got the numbers to combination need instructions how many turns
Right 3 turns, stopping on first #
Left past first # ONCE, then stop on 2nd #
Right to last number, pull OPEN
When me zanusi zwf1621w is draining at the end of the cycle it is leaking onto the floor
I do have the exact same problem. Please help. Also, there is a button that shows a spinning sign with an X over it. What does this key option mean?
1helpful
Spin refuses to work,shows a paddlock sign and nothing else works
Hold down the button where the padlock icon is for about 10 seconds...this should unlock the control.
5helpful
It says to release the lock switch. Where is the
Look on the bottom of the unit for a sliding switch that shows an icon of an open padlock on one side, and a locked padlock on the other.
Unlocked padlock showing and machine wont stop
It thinks the door is still open
So either it is or the door interlock switch is broken
4helpful
Dell latitude d505 wont start up. When I press the power button a flashing padlock shows up but the screen never turns on, then the flashing padlock stops, and thats the end.
The flashing padlock should have an "A" in it. That is the caps lock. The flashing caps lock indicates a problem with the memory slot. Try removing memory and replacing. If it continues and you have two modules, take both out and try one at a time. One of your memory modules or slots might have gone bad
7helpful
How to remove battery from compaq presario 2100
Hello there,
There should also be a switch to lock or unlock the battery.
It will show a little padlock. Turn it to the symbol with the padlock open, then pull the slide release and the battery should come out.
Thanks,
Lolita
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
