Question about GE 24 in. GSD4000J Built-in Dishwasher
GE GSD4000 sprayer arm replacement instructions
Sprayer arm replacement instructions
Posted by Amy Lee on
4 Related Answers
Carmen Mikulic
  • 415 Answers
SOURCE: Bosch sprayer arm found in bottom of dishwasher
how many pieces is the sprayer arm and how many sprayer arms to do you have 2 or 3?
Posted on Sep 13, 2008
Anonymous
  • 97 Answers
SOURCE: we have a GE dishwasher with upper and lower
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Posted on Dec 01, 2009
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: top sprayer arm on a
Hi
Check for the seal on the top spray arm. You'll need to remove the spray arm to check the top spray arm. Please check the removal procedure--
Removal and Replacement
1. Pull upper rack all the way out.
2. Remove plastic screw on bottom of middle spray arm. This will allow the middle spray arm and bearing to be removed.
Note: Install middle spray arm with spray jets facing the upper rack. Place bearing between spray arm screw and bottom of the middle arm.
To remove the upper spray wash arm, remove the upper rack. Then remove the screw and upper spray wash arm. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Oct 03, 2010
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: I have a ge pot scrubber quiet power 1 and I need
Hello, afossett
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
Little water to top rack
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 12, 2011 | GE Dishwashers
I have a ge quietpower 3 dishwasher. Lately it has stopped cleaning the dishes. Sometimes the dispenser tray doesn't open. Sometimes it does open and the soap pac hasn't disolved.
Make sure your water temperature is hot enough to dissolve the soap. Generally, the water temp. should be 140 degrees. Run some hot water at the tap before you turn on the dishwasher. This will assure that hot water is in the dishwasher as soon as you start it. Be certain that there aren't any large pieces in front of the dispenser tray. Sometimes casserole dishes, frying pans or baking pans can block the door and prevent it from opening.
Also, the sprayer arms might be clogged with bone fragments, peelings, bits of paper, etc. If this is the case, you'll need to remove the sprayer arm, flush and then check the jets. If you see "stuff" in the jets, they can be remove with tweezers.
Finally, make sure the upper sprayer arm hose is securely seated with the tube in the back of the dishwasher that carries the water up to the sprayer arm hose. If these two are not seated correctly, the water will not travel into the sprayer arm hose, the sprayer arm will not turn and your dishes will not get clean! I hope this helps. If it does, please come back to Fixya and rate my advice.
Jun 10, 2011 | Maytag Dishwasher
I own a GE Profile Trition quietpower III GSD5940F00SS dishwasher. The dishes, particularly the mugs and cups, are not getting clean.
Your sprayer arms may be clogged. You can remove them by loosening the screws holding them in place. Flush them with the sprayer at your sink. If you can SEE residue (parts of paper labels, bone fragments, fruit peel pieces, etc) remove them with a tweezer.Reinstall the spray arms and see if that works.
Three more ideas:
(1) run a cycle without dishes OR detergent and use 1/4 cup of white vinegar instead. This will break down soil and "gunk" and help your dishwasher run more effectively.
(2) use an old toothbrush and clean the underside of the door INSIDE the dishwasher. The door will be open and you just brush the bottom of the open door on the INSIDE of the dishwasher. A lot of "crud" gathers there and can be redeposite on your dishes. We seldom think to check that area.
(3) the pipe that carries water to the upper sprayer arm MUST fit against the outlet in the back of the dishwasher. If it is dislodged or not seated properly, the water won't flow to the upper sprayer arm.
Hope one of these suggestions helps. If it does, please rate my suggestion. Thanks.
Jun 03, 2011 | GE Dishwashers
Arms are clogged
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 04, 2010 | GE Dishwashers
The middle arm on my dishwasher (ge Profile) is not turning...the top and bottom are working fine
Had same problem with mine. Actually bought all new middle arm assembly but as I was taking it apart to install new pieces, I noticed so much gunk in the middle swinging mechanism that I assumed that must have been the problem.. I really think the newer dishwashing tablets cause this buildup problem. Anyway, put on all new pieces and started the machine. Long story short, it worked great for about a month and then started doing the exact same thing. THE reason why the middle arm sprayer doesn't spin is that the little holes at each end (the ones that sit underneath and look like they should propel the sprayer arm ) get clogged. I bought some pipe cleaners, bent to an angle where I could come in from the top and pull out through the propellor hole and voila` the sprayer is swinging beautifully again.. I guess the only question I still have is why this started happening three to four years after I purchased the machine. Something somewheres else must not be doing its job.
May 18, 2010 | Dishwashers
The sprayer arms will not rotate. What would fix
CALL THE PLACE THAT YOU BOUGHT THE DISHWASHER FROM AND ASK TO COME AND LOOK AT IT FOR YOU.
Dec 15, 2009 | GE Dishwashers
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
GE Triton XL Dishwasher not cleaning glasses
Check to see if the spinner holes are clogged with food..or debris...this is what makes the sprayer arms move....water pressure...which is pumped up through the sprayer arms .......I s the pump working...if so....then you may also have some blockage at the base of the pump where the screen is that keeps impurities out of the pump....check to see that food or debris is not obstructing this.
I hope this help....have a good day and good luck...please rate my effort...the Fang
Dec 14, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Aug 22, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
GE 24 in. GSD4000J Built-in Dishwasher Logo
Top GE Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Bill Johnson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
