Have your antenna checked at a place that knows what they're doing. If your antenna system is bad, ground problem,coax bad mount or maybe just a wrong or bad antenna. Then the sounds not getting out the antenna and its feeding back thur the radio.If your echo board was bad then your radio wouldn't transmitt at all.
If you unplug your external speaker will it squeal? If not do the antenna and if that reads fine just try a better speaker like a uniden 20watt speaker.I own a CB shop and this is easy to fix.
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
