Question about Dell E153FPc 15" TFT LCD Flat Panel Monitor
I have checked the power Fet, it is ok. All resistors and diodes checked ok with one leg off the board. The transistors are ok off the board.I changed the SM ic SG68410. It is getting only 5 volt vdd at pin 7 power supply instead of 30 volt. I have changed all the capacitors. There is 300 volt present at the main filter capacitor. Thank you
Maybe a bad cable, try and replace that. Possible a pin in the connector shorted or broke
Posted on Nov 04, 2017
SOURCE: Fuse F901: 3.15A always blowe up... Replaced Ic
Replace the regulator of your tv and the horizontal output transistor before replacing the fuse
Posted on Feb 06, 2011
SOURCE: Cannot power on the monitor
If this is the power section you are testing it is important that the switch mode frequency is present from the SM drive IC. If not the SMPS will not work. The diode will test only in one direction and if there is no leak it must be OK.Please check this link for tips. http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Dec 10, 2011
Replacement board: http://www.lcdrepair.us
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Basic LCD monitor troubleshooting guide:
