Tv tla-01911c pantalla blanca sin audi solusion
Tv tla-01911c cuando se da orden de encendido presenta pantalla blanca sin audio canales solusionar dicha falla muchas gracias
Posted by eliodoro leiton on
Mario. S.
  • 113 Answers
A lo mejor lo tienes enotra seleccion que no es la tv ( ejemplo como en auxiliar on en HDMI 1,2,3, ojala esto te ayude : - )
Posted on Dec 19, 2011
4 Related Answers
Ron Treat
  • 5 Answers
SOURCE: how to disassemble polaroid TLA-01911C lcd tv
1) Take the foot off the stand and with a long philips screwdriver remove the single screw that is at the top of the leg (inside leg). Then with the tv facing down lift straight up on the leg.
2) remove the two screws comming from the back of the tv along the bottom edge.
3) With the tv face down on a soft surface ( towel, bedspread, ect).
4) Be carefull with this step it this tv gave me some difficulty and I am experianced with this proceedure. Too much pressure or forcing it too hard will break your case. The back of the tv has a lip which inserts into the face.The face has tabs that lock into slots in the lip of the back. Carefully pry between the face and back pannel (I used my thumbnail and a 1" plastic putty knife.) and slide along the seam until the locking tabs pop loose. Continue sliding your instrument along the seam until all tabs are loose.
5) The back of the tv lifts off of the face leaving all electronics in the face of the tv.
That gets you into the tv. what you do from there is up to you, Good luck;)
Posted on Mar 19, 2009
Anonymous
  • 19 Answers
SOURCE: Polaroid TLA-01911C TV - I seem to have the same
I had the same problem - replaced the capacitors which cleaned up the signal. Then I hear a "buzzing" from the CCFL lamps. Turns out the solder job on the CCFL's themselves was shoddy and corroded. No good CCFL Power trips the inverter and turns the lamps off. Resoldering the wire to the end of the CCFL's fixed the problem permanently.
Posted on Dec 08, 2009
Anonymous
  • 19 Answers
SOURCE: Polaroid 19" TV TLA-01911C has no picture. Powers up, see logo
To add to this solution above - I had the capacitor replacement and there was still an issue. Turns out the solder connection to the lamps themselves was very very poor causing an electrical arc (the scratching noises people are hearing) - then the inverter shuts the lamps down as it should. Fix lights!
Posted on Dec 10, 2009
Anonymous
  • 12 Answers
SOURCE: PROB LEM WITH POLAROID TLA-01911C
It is related with Power
Posted on Sep 21, 2010
Mi tv mitsubishi presenta falla al momento de ver una entrada ya sea digital ..hdmi o rca se miran rayas purpuras de lado a lado alguien me puede ayudar
Tengo un Mitsubishi 73 inch el prende pero no se ve nada en la pantalla pero se oye despues de 5 minuto prende la bombilla roja y no se ve nada ni se oye
Mar 18, 2014 | Mitsubishi WD-62525 62" Rear Projection...
Tengo un acer aspire 5100 bl51 cuando la enciendo en la pantalla no aparece nada y esta toda negra no se que pudo suceder estaba descargando videos y de pronto se oscurecio la pantalla se escucho un...
Desconecta la bateria principal y Desolda una bateria chiquita que trae en la tarjeta madre (Posiblemente este debajo de la tarjeta Inalambrica).
Luego manten precionado el boton de encendido durante unos 10 segundos. Luego conecta todo y Listo. Ya que compruebes que te da Video le soldas nuevamente la bateria. Eso es Todo
Aug 30, 2012 | Computers & Internet
Tv lg 32ld330 enciende con sonido y sin brillo
Mi tv lcd es marca LG modelo 32LD330, al encenderlo se escucha y cambia de canal pero el video lo emite a mitad no da la imagen completa que puede ser?
Aug 18, 2012 | Televison & Video
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Por Favor me gustaria que me respondierais a la mayor brevedad posible y en español. Mi lg pdp42,estaba funcionando perfectamente y de pronto se escuchó un ruido,como cuando se va la luz,como si...
Podrias proporcionar el modelo completo de tu plasma?
Cuando proporciones el modelo te indicare donde esta la falla y tambien donde comprar la parte(s) para reparar tu TV.
Sep 12, 2010 | Televison & Video
Tv emerson 14" no tengo dato del modelo tiene los siguientes circuitos LA7671S---TA8782N---STR30110 ---LA7837, sintoma: le doy la orden de encendido, y primero le viene el sonido, luego se ve un...
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
May 21, 2017 | Emerson ET-14J2 13" TV
Tengo el problema q de mi portatil extensa 5230 series el encendido de la pantalla y el encendido del teclado me han quedado inutilizados, y no me deja utilizarlos en modo normal pido por favor un concejo...
Primero, se prende su computadora normalmente? Que hace su teclado cuando la computadora esta prendida? Hay algun error que aparece un su pantalla? Desde cuando tiene este problema? Installo algun programa antes de que pase este problema??
May 17, 2010 | Acer Computers & Internet
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
