The black screen says to push 'R' when i get to the first screen but whatever i do it wont go away
Ive tried shutting it on and off and pressing ctrl alt and otherbuttins but it will not leave this screen i cant get passed the screen to actually defrag it.
reboot using the key HOLD the key CTRL +F11 OR F12 depend of your computer model use restore factory default. or reboot using disck or USB. Other wise restart HOLD the key CTRL+F8with network, and use the CHKDSK command for repair.
Not sure, but try loading Safe Mode by pressing F8 during boot and lowering screen resolution. In Safe Mode you can even run System Restore. It load to a previous date that you choose.
Try pressing CTRL and the minus key -, at the same time, then keep holding CTRL and tap the - key again. This, on websites, makes things smaller. Let me know if that worked, or if not, post again and I will help further.
Try doing this. Turn off the unit, remove the battery, press and hold the power button (while battery is out), then put the battery back and turn it back on. If that doesn't work, just repeat the steps including removing the Sim Card. Or turn on the unit without a Sim Card.
You can also try using reset codes but that would reset EveryThing back to default settings which might include losing the settings of your provider which is not recommended. But the initial step is safe to use.
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
When the screen is black, try pressing Ctrl + Alt + Del; a soft reset should kick it back into gear. Did the laptop shut down unexpectedly due to power loss/overheating/etc..?
You need to go to HP.com and download updates. Sometimes the all-in-ones will need them after adding new ink. Also stay away from generics inks they will cause problems. Hope this helps.
Have you tried removing the battery for a few minutes and retrying?
yeah i did and it went straight back to it thanksthough
