Question about Hisense LHDN32V66AUS 32 in. LCD TV
What does it mean when the picture goes out? - Hisense LHDN32V66AUS 32 in. LCD TV
    Top Expert:
  • Hisense Master
  • 76,799 Answers
Hello
There are so many reasons for picture to gets out. The first amoung them, is of its backlight itself. If the backlight CCFL tubes wont light up, there will be no backlight to illuminate the picture. If baclkight inverter board has damaged, backlight CCFL lamps won't light up. The most common fault with LCD TVs are backlight failure itself. The second one is of with its main video processor board. In short, main board itself. You have to check and make sure which one is faulty. You must ahve sound knoledge in electronics to proceed. OK.
Posted on Dec 19, 2011
How to fix my Samsung tv ..picture goes in and out intermittently
The inverter board is responsible for the backlight so you can see the picture. If the picture just goes off intermittently then that means that the backlight is being turned off. And since the inverter board powers the backlighting you might want to look there.
Function settings
What model Canon camera? Do you really mean "previewing" or do you actually mean "reviewing"?
What does it mean when there is no picture and the standby temp light on continuously
It means the set is in shutdown and it based on model listed here has a power supply or related problem.
The picture goes to gray after an hour or so. Sound still works, but no picture. Picture starts to go bad...then goes gray. Is this a heat issue? Work good for about one hour...then goes gray.
When it goes gray, means that the T-CON goes bad after warm up or it does not receive the 12vdc feeding it from the main board, or the main board is bad, try running the TV with the back open with small fan blowing in the back, otherwise you can get a can of cold spray for electronics troubleshooting fro Radio Shack or repia shop and try cooling the T-CON bord or the main logic board with it to see will the pictures come back on. Also check the power supply for bad DC filter caps.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Screen goes off.
Is the power led button on, if yes, it means the picture board of your monitor is malfunctioning.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
1helpful
DELL 2208WFP LCD-Comes on normally, but almost immediately goes dark You can see something on the screen if you look closely. Turn it off and back on you see it then dark. any help?
I believe the power led button is still on while the screen goes dark, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes dark after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes dark.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
1helpful
Picture flickers & goes black
YES !!!! Mats Electronics has them $99.00
1-800-628-1118
Screen comes on then goes blank after 1 second
Is the power led button still on? if yes, it means the picture board is malfunctioning.
The picture board on your monitor is bad, since it goes black after a second, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
2helpful
3answers
Screen appears on for three seconds then goes black
Try the monitor on another computer that you know works, If it works on another computer then that means you have no video output on the original computer and you'll need to reseat the memory on that computer.
If you get the same response on another computer, then that means the monitor is bad and you'll need to replace it.
4helpful
3answers
Picture goes off but i have sound
I got KV 32ts 46 Sony
Turn on TV and seems OK, then no picture but have sound. I turn it on and off some time pictures come back but goes out again. Pleas help
Hisense LHDN32V66AUS 32 in. LCD TV Logo
Top Hisense Televison & Video Experts
Jean Sintulaire
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
