Hello Visit this site. You can get tie stereo wiring digram from here. www.modifiedlife.com/2005-jaguar-x-type-car-stereo-wiring-diagram/Cached - Similar
Here are the colours of the factory radio harness and what they do. 1995 Toyota Camry Car Radio Installation Schematic Car Radio Battery Constant 12v+ Wire: Blue/Yellow Car Radio Accessory Switched 12v+ Wire: Gray Car Radio Ground Wire: Brown Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: N/A Car Stereo Power Antenna Trigger Wire: Black/Red Car Stereo Amp Turn-On Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Tweeter Size: N/A Car Audio Front Tweeter Depth: N/A Car Audio Front Tweeter Location: N/A Left Front Speaker Positive Wire (+): Pink Left Front Speaker Negative Wire (-): Purple Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Blue Left Rear Speaker Positive Wire (+): Black Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Red Right Rear Speaker Negative Wire (-): White
use at your own risk. I can not confirm these.
+12V DC Battery(Constant)
Yellow/green
31
15 Amp
Fuse box on left front of engine compartment, near battery.
Switched Accessory
Purple
6
10 Amp
Fuse block behind left side of dash
Power Antenna
NCA
Green for antenna signal
Illumination
Red/yellow & red/blue
Steering Wheel Control Wire
Red/white, green, and blue
If equipped, as for Mid-Line.
Left Front +
Blue/white
Left Front -
Blue/red
Right Front +
White/black
Right Front -
Blue/black
Left Rear +
Green/yellow
Left Rear -
Black/yellow
Right Rear +
Blue
Right Rear -
Red
AT SPEAKERS
Wire Function
Color
Note
Left Front Tweeter +
Blue/white
Left Front Tweeter -
Blue/red
Right Front Tweeter +
White/black
Right Front Tweeter -
Blue/black
Car Radio Battery Constant 12v+ Wire: Green
Car Radio Accessory Switched 12v+ Wire: Green/Orange
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under the Driver Seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Tweeter Speaker Positive Wire (+): Blue
Left Front Tweeter Speaker Negative Wire (-): Brown/Red
Left Front Mid Speaker Positive Wire (+): Black
Left Front Mid Speaker Negative Wire (-): White
Left Front Low Speaker Positive Wire (+): Yellow
Left Front Low Speaker Negative Wire (-): Blue
Right Front Tweeter Speaker Positive Wire (+): Blue/Orange
Right Front Tweeter Speaker Negative Wire (-): Green/Orange
Right Front Mid Speaker Positive Wire (+): Black
Right Front Mid Speaker Negative Wire (-): Brown/Red
Right Front Low Speaker Positive Wire (+): Black
Right Front Low Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Yellow
Right Rear Speaker Negative Wire (-): Blue
use google. i did and i got this
Car Radio Battery Constant 12v+ Wire: Light Green Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black Car Radio Illumination Wire: Light Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: If equipped, the factory amplifier is located behind the trim panel on the right side of the cargo area. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): Dark Green/Orange Right Front Speaker Negative Wire (-): White/Light Green Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink
1992 Eagle Talon Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black Car Radio Accessory Switched 12v+ Wire: Blue Car Radio Ground Wire: Chassis Car Radio Illumination Wire: Green/White Car Stereo Dimmer Wire: Black/Yellow Car Stereo Antenna Trigger Wire: White/Black Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 4′ Car Audio Front Speakers Location: Dash Left Front Speaker Positive Wire (+): White/Blue Left Front Speaker Negative Wire (-): Black/Blue Right Front Speaker Positive Wire (+): White/Red Right Front Speaker Negative Wire (-): Black/Red Car Audio Rear Speakers Size: 6 1/2′ Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Yellow/Blue Left Rear Speaker Negative Wire (-): Gray/Blue Right Rear Speaker Positive Wire (+): Yellow/Red Right Rear Speaker Negative Wire (-): Gray/Red -->
I have the same problem, the speakers are "burned", you need to repair them or change them, I went to a place where repair car stereos, old tvs, etc., they "rewire" or change the wires in the back of the speaker, where regular speakers have magnet, he told me not to replace the speakers for another ones, he told me that this ones are Alpine (they don´t have any label) speakers and that they are better than most commercial ones, he charge me about $50 usd, Good Luck!
You need to know if these are Pizo tweeters or dome tweeters. If Pizo just hool them up to the white and gray wires off the kenwood. if not, then you should go to your local stereo shop and by bass blockers (small capacitors will do). this is only to "erase" the ohm load. once you have those inline of the POSITIVE wire you can hook the up to the gray and white wires. Good luck hit me back
