For what your saying its the video board...either its shot or voltage from the power board it not what it should be..check for bulging caps and for burnt spots on the boards...video board has all the inputs power board can be found by following the power cable...please make sure to have the unit unpluged before servicing
SOURCE: Sceptre X32GV-Komodo
Please set it to auto mode. And see that you have put the signal in right position and place
SOURCE: My Sceptre X32GV-Komodo got a problem recently: I
This type of issue is usually caused by blown capacitors on the power supply board. If you wan to do the repair yourself then go to our web site at: www.ccl-la.com/capacitors.htm and look at the pictures of what to look for in your monitor. Now open the unit and look for the power supply board, replace all parts hat look like the pictures and have even slightly bulging tops. The page on our wen site gives more information about the replacement parts. If you need to order parts we do stock them for same day shipping. If you don't want to do the repair yourself we do offer a repair service for your model for $45 plus return shipping. Let us know if you have any additional questions by email at [email protected].
I hope this helps you, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: sound but no picture
Most likely - the CCFL backlight is not getting the power it needs to come on. You can verify by shining a light on the front surface of the set - if you can just make out a dim image, then that is it. On some sets, the CCFL can be seen through the vents on the rear.
SOURCE: new Sceptre 37" LCD TV does not turn on
I just got a 42" komodo by Sceptre, same problem, except "SCEPTRE" showed on the screen. I was sent a USB key program to insert in the service slot in the back and it reflashes the bios. This is old news for you but maybe new for someone?
SOURCE: My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
