Question about Hitachi 43F300 43" Rear Projection Television
I have a hitachi 62 inch tv 62vs69a that turns itself off after an hour or two and wont come back on until it has set for a few hours whats wrong with it?
Posted by Melanie Morse on
2 Related Answers
Anonymous
SOURCE: Hitachi 50SX6P 50 inch television
Friend gave me a Hitachi Ultravision 50SX6P
I can see why ... he got rid of it
anyway...I need the manual
How can I get it
Need to get rid of yellow outlines
Posted on Jun 21, 2008
Anonymous
SOURCE: 62 inch hitachi LCD blue streak
My LCD Hitachi did the same thing and it was the light engine, Hitachi paid for it because it was a big problem in a lot of the TVs...
Posted on Feb 28, 2009
I have an hitachi 62vs69a that has blue streaks on the side with a yellow tint? how do i fix it?
BLUE STREAKS AND YELLOW TINT describes almost perfectly a bad optical light engine--no do it yourself repair and engine is well over 600 dollar part exchange.
The shutdown may or may not be related but it does not matter--time for another (in my view) TV.
Apr 02, 2012 | Hitachi 62VS69 62" HDTV
My hitachi 57f500 turns itself off after 3 hours of use. Turning it back on restores the picture,
Hi I am Vortash
There may be actually nothing wrong with your set ? .......
This set has an anti surge protection circuit and it is designed to shut down should the incoming power peak above 240 volts or more , is this happenig at random times or around the same time in the evening or day it may be that this safety device is protecting the set .. sometimes local area transformers peak at the time of most consumer requirements this may just coincide to when you sit down to watch tv .. however if it has a habit of doing it at different times during the day .. then this safety circuit may be at fault and require an engineer to service the tv and check for poor components that have changed value .. It explains this is in the manual if you do not have one for your set you can download one for free from http://www.safemanuals.com hope this is of help regards Vortash
May 20, 2009 | Hitachi 57F500 57" Rear Projection...
Cant find repalcement lamp for my tv
I have a repair shop I use that will find and order it for you. Talk with Frank SR. at Audio Tronics in Cherry Hill NJ his shop number is 856 6670190. Open 10-5m-f 10-2 sat sunday closed.
Mar 17, 2009 | Hitachi 62VS69 62" HDTV
Tv powers off and on after operating for about 1 hour
Same happened to me with my old panasonic set. It was a dry-joint. You can try re-soldering the circuit.
Good Luck.
P.S. - Check the Power Suply area closely.
Feb 20, 2009 | Hitachi 60VX915 Rear Projection Television
TH ETV TURN OFF ITSELF
the cooling fan could be going out
Dec 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
My 50" hitachi ultravision won't turn on
i got a 62VS69A model type hitachi tv.... and it was thunderin and lightning outside all day .... and i left it on ... and when i woke up ... it was off..... and when i went to turn it back on.... it blinks blue,, then the light below it blinks red.... and the light below that light blinks red .... and then the first blue one again ... and over and over again ... untill finally it juss stays red... i donno whats goin on with this tv... im assumin it was the bad weather outside that did it but im not sure..... can someone PLEASE help a brother out ? lol
Nov 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Apex pf2025 20 inch tv
timer set in menu options. Mine did the very same thing until I cleared the timer
Oct 13, 2007 | Apex Digital PF2025 20" TV
Open Questions:
Hitachi 43F300 43" Rear Projection Television Logo
54 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
