Question about Danby DWC283BLS Wine Cooler
My wine cooler works well but it make noise while running, I suspect could be compressor, What should I do?
Posted by Naresh on
Mike Jones
    Habit-Forming:
    Scholar:
  • 106 Answers
There is not compressor it a cooler not a fridge... The noise is most likely fans 2 of them one inside and one under the rear cover. remove the bad one take to R Shack ... computer fans are about the same size.
Posted on Dec 28, 2011
Whirlpool 22" wine refrigerator wwc287bls. Makes a high pitched sound pretty much constantly (compressor seems to run constantly too)
Howard, We're sorry to hear about your Wine Cooler making a high pitched noise. Our Wine Coolers are handled by a different department. Please call 800-263-2629 for assistance.
Jun 13, 2017 | Whirlpool Refrigerators
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
Making noise
not to many moving parts on that wine cooler more then likley it is the compressor making the noise. check your warranty to see if the compressor is covered
May 12, 2011 | Haier BC112G Wine Cooler
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
Set temp to 42 and 54 but unit stays at 75. HELP!
sounds like the compressor is not running . ck the connectons at compressor and listen for a click in the cold control as it may be bad .. / noises like clicking at compresor . may be the relay that starts it .. mm
Aug 09, 2010 | Danby DWC283BLS Wine Cooler
Electricity works, unit doesn't cool.
Hi and welcome to FixYa. I am Kelly.
This is a 6 or 8 bottle free-standing wine cooler from what I can tell.
I am not having much luck determining if this is a manual defrost type unit or not. Given the inital sales price now of $79.95 I have to assume it is a manual defrost type.
There are a few things that can cause your problem.
1. PTC relay and KliXon thermal overload assy on the compressor.
2. Run capacitor
3. Temp control
You said the fan does not run so I cab not rule out the temp control.
I can not even find a parts break down of the unit.
With no fan running the very first suspect is the temp control but you can at least listen for a CLICK when you cycle it from off to any other position. If you hear a click I would start looking at compressor start / run parts.
If you have access to your units compressor note the manufacturer, hp if stated (1/8hp etc) and Model number.
Then call or visit your local appliance parts supply store with that information in hand. The will have a PTC relay / KilXon thermal overload AND run capacitor that will fit your unit. I am pretty sure that will get you going again UNLESS you have a broken wire somewhere.
The replacement parts are going to run about 50% of the cost to replace the whole thing.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Emerson (025806803716) Wine Cooler
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Danby DWC283BLS Wine Cooler Logo
569 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
