Bluetooth activated on phone,but does'nt find my handsfree multipoint speakerphone which bluetooth specification is v2 1+EDR.manufacturer says that it is compatable with my model phone.
SOURCE: bluetooth handsfree problem
Bluetooth uses a technique called spread-spectrum frequency hopping. It changes frequencies 1,600 times every second. A frequency of 2.45 gigahertz (actually between 2.402 GHz and 2.480 GHz, to be exact). For the bluetooth device to work at 100% it needs to be 100% compatiable. More than likely, if you change your earpiece device, you should be able to pickup your songs. If you go to the VerizonWireless website, they should have 100% compatiable devices. Todays Tivia: Harald Bluetooth was king of Denmark in the late 900s. He managed to unite Denmark and part of Norway into a single kingdom then introduced Christianity into Denmark. He left a large monument, the Jelling rune stone, in memory of his parents. He was killed in 986 during a battle with his son, Svend Forkbeard. Choosing this name for the standard indicates how important companies from the Nordic region (nations including Denmark, Sweden, Norway and Finland) are to the communications industry, even if it says little about the way the technology works.
-Press the Navigation key to access the main menu.
-Scroll to Applications and press the Navigation key.
-Scroll to Bluetooth and press the Navigation key.
-Press Options.
-Scroll to Settings and press the Navigation key.
-Scroll to Activation and press Navigation key right to select On.
-Scroll to My phone's visibility and press Navigation key right to -select On.
-Press Save.
-Start the GSM dial-up connection (C3050 GSM) you have set up on your computer.
-The display shows that the number is being dialled.
-When the connection is established, you can access the Internet from your computer.
By the steps above, you can use your Samsung C3050 as a modem successfully. May this article can help you.
