My incoming and outgoing email settings may need some professional knowledgable person to help me in setup.I can receive email but cannot send it; at least I cannot send estimates and invoices to customer's email.I have comcast as a provider and home page, gmail, windows mail, google and I believe windows live.Hope someone can help me. Merry Christmas and have a happier new years everyone !
SOURCE: cant install pro venture invoice on my new vista computer
proventrue v1.0 is not comparable to latest WIndows OS.
the proventure v4. is the latest listed on their web site. and yet it is only comparable to Windows Xp.
you can try that one. but there is no garrenty it will work. cost for the upgrade is $8.00 cheap enough.
SOURCE: I am using Proventure 2
Usually when such problems are encountered the best way to transfer your invoices would be to copy them to the new machine.
Invoices are usually created using the program and when created are
saved somewhere on the unit usually the documents folder. Often times
the program creates a folder under my documents where it stores created
invoices. Once the program is installed on a new device if you locate
these files on the old device and you copy them to the new device your
invoices will be on the new device.
Try locating all files on the PC relating to the program and carefully examine them one after the other to locate the invoices.
Feel free to ask further assistance.
Hope this solution has been helpful?
SOURCE: when i try to open
Hello.
Sounds like the file you are trying to open is corrupted. If you have a backup file, backup the current file for safekeeping and use a recent backup file.
When
the program prompts, then creates a backup file for a database, it has
a .bak suffix. However it also creates a folder in the 'Safe'
folder under c:\program files\estimates. Locate the most
recent version of the db files in the Safe, copy the folder to the c:\documents
and settings\...\Invoices directory, and the most recent uncorrupted database should be available.
Hope this helps.
SOURCE: Hi, I bought the unlimited
Yes there is a way but it's too time consuming for me to explain it in text. Anyways, I will give it a try. Kindly give me following more information.
1. Do you wan't both the computers to be on internet.
2. What is the format and folder in which your invoices and estimates are saved.
3. Who generates these invoices and estimates. yourself or you download it from somewhere else.
SOURCE: Hi I purchased Proventure invoices and
The issue is that your choice is an old program ..and do not have an update for windows 7 ..
you can try to download it ..and install it ..and after you install it click right on the execution ..and properties...than choose compatibility ..and select to run in compatibility with windows XP..
You have a 70% chances to work ..but this is not a sure thing ..
Another issue with this one ..is that it is only available on disk ..and you have to order one ..or use the old one if you still have it ..
http://www.shop.avanquest.com/usa/prod.php?pid=4059&pdis=1&tr1=AQ_US_WS_BOS_homepage
or ..try another software ..compatible with windows 7
http://www.amazon.com/Avanquest-10061-MyInvoices-Estimates-Deluxe/dp/B00269D9LU/ref=pd_sim_sbs_sw_2
this one is compatible with windows 7
or try this one ..which is compatible with vista and windows 7 ..and has a 30 days trial ..
and it is download-able
http://en.kioskea.net/download/download-1149-my-invoices-and-estimates-deluxe
I would give a try to the last one ..just to see if will suit my needs..
