Hi Paul,
Here's the manual in pdf.
Hope this helps.Thanks!
Testimonial: "Thankyou very much for sending the kenwood,KDW12ST3A, user manual to me. It's a big help to me as it comes in very handy! From Paul."
SOURCE: I have a kenwood KDW12SL3A.
Just got one of those at weekend and had e4 code-looked up on here and gor tis solutionwhich sems to work!
To clear the fault you need to remove the two baskets from the dishwasher.
Slide it out from under the worktop and lean it forward to about 45 degrees.
If it is already full of water, turn on the power whilst pushing the programme button, this sets up a pump out program
SOURCE: I have a kenwood dishwasher
aye have same problem!? how did ya get it fixed if ya did thanks
SOURCE: Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
SOURCE: my kenwood KDW12SL3A dishwasher dysplays
Hi
E3 error code neans the water is not being heated to the required temperature in the machine.
This may be either a defective heating element or faulty thermostat.
It is unlikely you can fix this yourself.
Depending on what is wrong it might cost you around $150
