Question about Logitech X-230 Computer Speakers
My left chanel stop working, anyone has a wireing diagram for this unit ?
M/M S-0123
  • cool_croc
    cool_croc Jun 17, 2012
    Yeah same with me please tell me if youy found how to fix it or found diagram :P
One side dead
hi zm_16dec,
Right chanel fully dead , output transistor burnedout ,
Without knowing the make and model of your amplifier
all i can advise is to replace the unknown part number of
the transistor.
Look for the working left channel output transistors and
replace the bad transistors in "pair". These may include
other components but check on it as well.
Check the speaker system, especially where that channel
is connected.Inspect speaker wires or cable up to the speaker
itself.
Amplifier wont blow without reason.It could be from the wirings,
speaker or volume settings of the unit.
Thanks for choosing Fixya for assistance!
Gateway 5300S Desktop PC - need original Gateway PC BIOS
in my past experience when you change drivers or bios, you should be able to unistall the new and restore the old. if you go to Gateway web site enter your model info or tag into search, it will provide the bios, drivers and software updates to your model. if you pick BIOS when your model info is displayed and download it, it should be the old one or original if no updates are listed. the links sent you may have answered this already. i have gateway pc so thats what i do.
3helpful
I need a wiring diagram for a generac gp15000e generator
I have a 15000 ultrasource generator the start and stop switch was taken out i need to put it back The problem is i dont know which wire goes where and when i look at the wire diagram the numbers are different the numbers on my unit are 15, 11, 133, 14, 12, The 15 and 11 are the same wires the start and stop switch has 6 males on the back to plug the wires into Does anyone know which wire goes where???
4helpful
2answers
How to unlock the locked key. LG TV
A lot of the main codes are 1234 or 0123 or longer in sequent (12345) give those a try...if no luck write back I will research.
18helpful
I dont have a wiring diagram for the 16 pin plug on a deh-p2500 pioneer car stereo. Can Anyone help? It is a used unit.
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
JVC dual channel bridgeble Amp
Most repair shops offer a warranty. If you've recently had it repaired, return it to the shop to have them check it out. If you continue playing it as it is, more damage may occur and the additional damage isn't likely to be covered by the warranty.
JVC dual bridgeble AMP
Have the speaker checked out and if it checks good you need to take the amp back to the repair center and have them test it better. Most repair centers have a 30 day warranty on the work they perform. Make sure they know what the problem is in detail, so they know how to check it properly. But my first thought is the speaker could be faulty. You can check the speaker yourself by switching them at the amplifier. If the same speaker sounds bad you know it is the speaker that is bad. If the sound is bad from the other speaker, then the amp is bad unless it is coming from the head unit. You can also switch the RCA input jacks after that and see if the problem changes speakers, if so, the RCA output of the head unit is bad, but that is less likely.
3helpful
Hooking up system
You have a green orange and black connection, hook those to the subwoofer, on the other end of each of those connections is a split connection which splits to a Red/White cable that is provided, correspond the red/white to your dvd unit as such (Front Left, Front Right, Surround Right, Center and Sub), if your dvd player only has a 1 white/red port then you will only be able to use the 2 chanels, so just 1 split will be required.
14helpful
5answers
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
1helpful
Wiring Diagram
Did you get this figured out?
Logitech X-230 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Mandeep  Singh
Mandeep Singh
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
