When i push input or volume or even power the tv does nothing i have to unplug it to turn it off. now i have no remote for it so i feel limited on what i can do. is there maybe a way to reset the tv or something like that. unplugging it and let sit for a day or two does nothing to it same problem
Time to put that old TV out of its misery. They are not worth trying to fix, especially when you can purchase a new and far superior TV for $500.
Example: https://www.bestbuy.com/site/samsung-55-class-54-6-diag--led-2160p-smart-4k-ultra-hd-tv/6051108.p?skuId=6051108
SOURCE: Maxent MX-42VM10 42 Remote
Trying to program a universal remote can sometimes be a frustrating process. Successful programming of a universal remote depends on whether the universal remote manufacturer included our company’s information in the remote when it was assembled.
Then a cable company (ie., Comcast) or satellite provider (ie., Dish Network) orders their decoder box and universal remote control from a manufacturer (ie., Scientific Atlanta, Motorola, etc.), the decoder box manufacturer provides a list of all the possible remote controls this universal can duplicate. From that list the cable company or satellite selects which manufacture’s products to include on their new universal remote. Once those manufacturers names have been decided, they are placed on the universal remote and a numeric code is assigned. If they choose not to include our company on the universal remote, the universal remote may not access the Maxent screen.
If you cannot locate Maxent on the list provided to you by the universal remote provider, please try the following:
Through contact with various cable and satellite content providers we have developed a list of the most common numeric codes that are used with universal remotes.
Content Provider/Most commonly used code
Comcast: 1755
Comcast (ML-3251HLT Model): 0054
Insight: 1755
Direct TV: 11755
Dish Network: 742
Cable Vision: 165
Adelphia: 0156, 1755
Universal: 0762
One4All: 0036
Time Warner: 0230
We have identified other manufacturers of display products that have similar remote control information to ours. Depending on the universal remote you are using these manufacturers may work. Please use the documentation that accompanied your universal remote, and look up the following companies. Input the numeric code associate with that company.
Gateway
Sampo
Viewsonic
Magnavox
Phillips
Marantz
Pilot
If the universal remote you are trying to program contains a Code Search (the remote will scan through all the codes contained within the universal remote) function, we recommend that you try that procedure. It is possible that there may be another manufacturer code that may work with our monitor.
You may also want to try a Learning Remote from another manufacturer. This type of remote control can absorb or record the information coming directly out of the Maxent remote control. The learning remote then duplicates that information and acts like the Maxent Remote control. This type of remote can also record the signal coming from your other universal remotes in the same manner. In which case you can use this learning remote for your entire audio video system
SOURCE: the TV does not respond to the remote control nor the buttons in the front panel
i am haveng the same problem p58h10nja
SOURCE: Maxent p4202yd05
have you tryed to find the "lamp" on it ... it sounds like your lamp has gone out you can get them from walmart or best buy or another type of electronics stores... they are normaly cheap compared to the price of a new tv and all it is is a light bulb for your tv... good luck to both of you
SOURCE: Maxent MX-42XM11 Television Power Problem Problem
i was having the same problem and the power supply board was out
SOURCE: 50" maxent green light no picture
WWW. maxentusa.com. Sounds like your power supply board is bad or you have a shorted board somewhere. Maxent is still in business and they are pretty good at customer service.
phone 1-888-373-4368.
