Question about Kingston Computers & Internet
Pls. help me ..about my usb (kingston 2GB)..i can't format it and copy some datas!!!..it says that the drive is write protected..and i don't know how to fix it!!..please help me!!
Posted by marilou on
Catalin Turcu
  • 4,924 Answers
If it says the drive is write protected it means either it was formatted this way ..and for to see if it is so click right on it ..and choose properties and in there take a look not to be ticked on write protected ..or if it is selected read only ..remove the mark and click apply ..
If this is not a case..check the files inside not to have such a issue ..delete files one by one ..and check the ones that do not want to remove themselves..and do just like I suggested .In the last resort ..try to download and install remove on boot program ...and select tye files into the program ..and delete them on boot if they are write protected..
The action itself is to click right on the file that can not be deleted...and select to remove at next boot ..(the program will add this option on the menu ) and once selected all ..just restart the computer ..
here is the link for the program ..but lets hope it will not be needed..
After all files are removed..open the flash drive folder and under organize,,folder and search options ..click on view and select to see hidden folders ..and if there are any delete them too ..just to be sure ..
Last ..just click right on the drive's icon ..and select format ..select the options for to do that and go for it ..
here is the program I mentioned..
http://www.softpedia.com/get/System/Boot-Manager-Disk/MoveOnBoot.shtml
Posted on Dec 17, 2011
5 Related Answers
Anonymous
SOURCE: write protected
kiick azz.. u might try copy files from cd that has write protection.. i still try 2 find the solution..
Posted on Feb 11, 2008
Nikos Kefaleas
  • 7 Answers
SOURCE: HOW TO FORMAT A WRITE PROTECT USB DRIVE
try this tool HP USB Disk Storage Format Tool!!
Posted on Feb 25, 2009
rustysheriff
Tony Groves
  • 344 Answers
SOURCE: Remove the write protection on 2GB USB Kingston Data Traveler 100
Found this on Kingston site, doesn't help much but may point you in the right direction.
Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
  1. Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
  2. Make sure you have not enabled write protection on the drive by using a third party software.
  3. If none of the above apply, the drive may be defective.
Posted on Jun 02, 2009
ikkenom
  • 10406 Answers
SOURCE: I HAVE A 4 GB
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK q: /F
where 'q:' is the drive-letter assigned by Windows to your Kingston.
Press Enter.
When "check-disk" has completed, Windows will remote the "write-protect".
Posted on Nov 13, 2010
Anonymous
  • 4 Answers
SOURCE: my 8gb kingston usb falsh
no need to worry friend first you need to active the usb port and then fix the pendrive to usb
follow bellow steps
---> ctrl+R
----> in this tyoe " cmd "
-----> in command prompt type usb drive name
examle : if drve is H then type like H:/ or F:/ etc
----> format H: or format F:
-----> if any question ask then u aswer yes press "Y"
----.> your problem is solve
in case failure then you can try this another operating system or another computer
Posted on Feb 22, 2011
My Kingston 2GB USB is write protected. i dont know how to remove it coz i cant delete copy or format it
Check the USB device to see if there is a switch that makes it write protected. If so, change it back. If you're still having problems, it's probably defective.
Mar 16, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hii sir pls help me mine kingstone data traveler 2gb is write protected so how shall i remove write protected?
Copy all the files onto your 'C:' drive.
Spend $9 to buy a new 2GB USB memory-stick.
Copy the files to the new memory-stick.
Take a sledge-hammer to the old memory-stick -- to prevent anybody else from reading your files.
Oct 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Not able to copy more than 1GB into 2GB Kingston SD card
Hi 1123sun,
Copy your files off the card. Then Format the card and select FAT32 file system. After the format is done try the card again and see if you can copy more files to it.
Kingston Tech Support
Feb 18, 2009 | Kingston 2GB Secure Digital Memory Card
Kingstone 32GB Pendrive problem
this must a result of virus, check your pen drive witha updated virus cleaner and also protect your system with a lattest virus gaurd.
Jan 15, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
USB Drive - Write Protected
Hi.
While formatting chose default allocation unit.
If this doesnt helps the tell me.
Regards
Faraz
Oct 16, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Write protect Error
Hi ............
last month i purchased 4 GB pen drive. now it working in Write protected mode and accepting 1 GB data transfer. please suggest me solution for this problem to my mail ID
[email protected]
Sep 04, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
330 people viewed this question
Top Kingston Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Mike
Harish  Ramaiah
Harish Ramaiah
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
