Pioneer GM-X332 Car Audio Amplifier Logo
Fred Taylor Posted on Dec 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How many total watts - Pioneer GM-X332 Car Audio Amplifier
Level 3:
Top Expert:
  • Pioneer Master 76,851 Answers
  • Posted on Dec 18, 2011
Pioneer Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15004424
Points
237762
Hello
The power rating for this amp is as follows.
Two channel: Sub woofer: Min 35Watts
Two channel: Other than sub woofer : 70Watts
One channel: sub woofer; 100Watts
One channel: other than sub woofer: 200Watts.
OK.
1helpful
Hi,I have two 250w speakers at 8ohms ,could someone tell me if I need to get a amp with higher watts than the speakers?k
Speakers are rated either at RMS (root mean square) average power or Peak Power. An RMS of about 125 watt is equivalent to 250 watt peak. To match the radio and speakers they both need to be consistent. Also do not be confused with total radio power out vs per channel.
So if the speakers are 250 watt peak power then a radio with 125 watt per channel or 250 watt peak per channel would be a good match.
If the speakers are RMS 250 watt then the radio would be 250 RMS/channel and usually with a four channel radio a total of 1000W RMS
With that much power the neighbors should hear you coming!
What is the wattage breakdown for each speaker on my pair of Pioneer CS-N575 3 way speaker towers (I know the total max power combined output is 150 Watts)?
It's the woofer that will use almost all from this 150 W so if you replace woofer take one of 8 ohm which can handle 150 W and you done
1helpful
2answers
What do i have to know about watts in order to work out each appliances power usage aday
Add up all the wattages of the appliances you are using when they come on and go off including lights. fridges. freezers, fans , stoves, tools and every thing. add them all up and you will get thousands of watts called kilo watts . see how many you use per hour and you will get a kilowatt/hr usage rate. Find out the power cost per kilowatt/hr and multiply the usage by the cost and you have your answer. Or you can get a wireless transmitter that is clamped around the input line to your premises and it transmits to a receiver to inside your house (mine sits on the fridge) and it tells you the cost as everything is running . press the mode button and you get progressive cost and other modes are there as well. It is great because if I forget and leave the pool running I can see at a glance that something drawing a lot of power is running so I can check it out and turn it off. Ask you power provider about it or a good electrical shop.
No lights upstaires circuit breaker keeps tripping
Jan 2013
1) Move wire to another same-size circuit breaker to eliminate bad circuit breaker as suspect.
Do NOT increase size of breaker or it will cause fire.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html
2) Put hand on each appliance and outlet to see which ones are warm. Outlet should never be warm or hot. Replace outlet. Inspect wires for loose and burned connections.
3) If the breaker is good, then add up total watts being used by checking watt rating on each device. 100 watt light bulb is 100 watts. Big screen TV has a label that shows 300 to 500 watts. Computer has label. Space heater has label showing 1500 watts. Iron has a watt rating label. Take total watts and divide by 110Volts and this will give amp load. Total watts used = 2000 and then divide 2000 by 110 volts = 18.8 amps
Compare amp load with circuit breaker.
20 amp circuit breaker has 80% safe maximum, or 16 amps.
If amp load is 18.8 amps, then 20 amp breaker is starting to get hot, and weak breaker will start tripping.
If amp load is 18.8 amps, and breaker is 15 amps, then you are overloaded and breaker is feeling the heat, and tripping because of heat.
Solution is to reduce amp load.
4) If you have short circuit, that can also trip breaker.
Unplug everything and then plug things back in slowly to see which plug or appliance is causing the problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
IM67 sound system
The center speaker 900 watts, the two speakers on sides 300 watts each and the subwoffer 500 watts. Total of the speakers power 2000 watts.
How many lights or ceiling fans can I hook up to one 15a single pole circuit breaker.
First of all, are there any other appliances or lights on this circuit? If so, they must be included in the total wattage for the circuit. The fan units are either listed with the Amp rating or wattage rating (Volt Amp) VA. The total amperage allowed on a 15 A circuit is 12A.(80% of the total per NEC). The total wattage would be 1380 watts. ( 115 Volt single phase X 15A = 1725 watts, 1725 x 80% = 1380 watts)
1helpful
2answers
What is the total WATT output on the Sony MHC-G101 mini hi-fi 3 CD changer, dual cassette home component system? I misplaced the owner's manual, and I want to know how much power it has. // Tks
According to page 24 of the manual, it delivers 11 Watts RMS (route mean squared) per channel into 8 ohm speakers.
Elsewhere in the manual, you'll see references to "15 watts per channel" and as much as "25 watts per channel". The 15 watt value is valid when putting up with some 10% THD (total harmonic distortion), this value is 11 times higher than the .9% THD value given for 11 watts per channel. You tolerate .9% THD now, but you wouldn't want to listen to anything with 10% THD. The 25 watts per channel is what they call "Music Power". Watts is an electrical term, "music power" is not. You could use it to compare other devices that only offer "music power" values, but the best indication of how it will perform is based on watts in RMS, into an 8 Ohm load (most speakers are 8 ohms). The lowest THD values are best.
From the manual:
AUDIO POWER SPECIFICATIONS
POWER OUTPUT AND TOTAL HARMONIC
DISTORTION:
With 8 ohm loads, both channels driven, from
70 - 20,000 Hz; rated 11 watts per channel
minimum RMS power, with no more than
0.9% total harmonic distortion from 250
milliwatts to rated output.
I hope this helped!
1helpful
How many total watts does this system have
Well... It consumes 240 watts of electrical power total so take the audio power specifications with a huge grain of salt, as no audio device puts out in audio power anywhere near what it consumes in electrical power. Heat produced is power consumed, too and nothing is 100% efficient.
In the specs below the only information useful for comparison is in the line I highlighted with >>> <<<<'s as it conforms the closest to the industry standard practice of using:
"X watts into 8 ohms (standard load) from 20 - 20000 hz plus or minus Y db at no more than .0Z% distortion"
The better amps specify vanishingly low distortion specs (0.0x% vs 0.x%) at the cost of being able to claim higher wattage. But they guarantee cleaner sound at the claimed levels.
JVC is being tricky with their choice of a 40 hz lower limit. THAT is the power hungry end of the spectrum. 20 hz is normally the lower limit stated.
"Output Power .............At Stereo operation
Front channels .............55 watts per channel, min. RMS, driven into 4 ohms at 1 kHz, with no more than 0.9 % total harmonic distortion. (IEC268-3/DIN) 30 watts per channel, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.9 % total harmonic distortion. (IEC268-3/DIN)
>>>>> 30 watts per channel, min. RMS, driven into 8 ohms, 40 Hz to 20 kHz, with no more than 0.8 % total harmonic distortion. <<<<<
At Surround operation
Front channels .............50 watts per channel, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.8 % total harmonic distortion.
Center channel .............50 watts, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.8 % total harmonic distortion.
Rear channel .................50 watts, min. RMS, driven into 8 ohms at 1kHz, with no more than 0.8 % total harmonic distortion."
Can you tell the wattage of the onkyo tx 905 not the home theatre model stero only
140 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven from 20 Hz to 20 kHz, with a
maximum total harmonic distortion of 0.05% (FTC)
170 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven at 1 kHz, with a maximum total
harmonic distortion of 0.7% (FTC)
180 watts minimum continuous power per channel, 6 ohm
harmonic distortion of 0.1% (FTC)
Home stereos
Hi this is Compaqowner again NOTE: I know enough about home Stereos,and I am pretty sure to figure out 'power output' you take the total:in this case it takes in 110 watts total devide that by 2 so according to my math that is 55 watts (I guess this AKAI has a 55 watt amplifier) then you take the amplifier output (in his case 55 watts) and devide that by how many channels are being used,so in 5.1 DOLBY mode DVD movie,etc.(power to all 5 speakers) then it's 11 watts per channel,and in 2.1 stereo (power to the subwoofer,front right,and front left speakers only) it jumps up to a little over 18 watts per channel,again,I think?,when you find the answer,please let me know. Thank you for your time. Steve B.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
