Question about Fuji FinePix F47fd Digital Camera
Fuji j28 lens zoom error
When turning on the camera lens retracts and displays zoom error
Posted by richard male on
CameraR
  • Fuji Master
  • 4,738 Answers
Here are some troubleshooting steps that you can try that may (or may not) correct your problem. They only seem to work for less than 40% of the lens/zoom errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
And here's a video summary of the steps:
Posted on Dec 21, 2011
I have a zoom error alert on the screen of my fuji j37 digital camera. When i turn the camera on the lens comes out and retracts straight away.
I had this problem for the first time yesterday, on my fifth use of the camera from new. The user manual says to turn it on and off a few times which I did but to no avail. I found advice on a different forum that said to hold your finger over the shutter as you turn it on, so that the lens doesn't have time to retract again. Sort of use your finger nail to hold the shutter up while the lens extends. Tried this and it worked, switched it off and back on agiain and it seems to be going fine now.
May 16, 2010 | Cameras
Digital zoom error on an A600, lenz will not retract either
Have you tried spraying a can of compressed air into the lens assembly? All it takes is small piece of debris like a grain of sand to jam up the assembly.
Hope this helps
Jul 07, 2008 | Fuji FinePix A600 Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
I have got a zoom error on my fuji Finepix V10. When you turn the camera on the zoom starts to come out and then quickly retracts. How can I fix it?
Sounds like the timing for the sensors on the lens are out and will need to be reset.
lens unit will need to be removed and reset
Jan 02, 2010 | Fuji FinePix V10 Digital Camera
How do I fix the Zoom Error for Fuji Finepix F47fd? I can't even extend the lens fully like what previous posts stated
Hi Jasmine,
With fresh batteries inserted in your camera, try to do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Dec 13, 2009 | Fuji FinePix S304 Digital Camera
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Jun 26, 2009 | Fuji FinePix A600 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Zoom Error
This would not be recommended by technicians but if you can not get any one to fix your lens you could try this, i have done this to a few cameras(which had been dropped) and they worked after. If the lens is obviously not straight and will not retract. Place the camera on a flat surface and starting gently pull lens to straighten it gradually increasing force until it clicks into the correct position. As i said you do this at your own risk, it will not work all the time but sometimes. Good luck
Apr 03, 2008 | Fuji FinePix F10 Digital Camera
Lens not retracting
if the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
Apr 01, 2008 | Fuji FinePix S7000 Digital Camera
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Fuji FinePix F47fd Digital Camera Logo
279 people viewed this question
Top Fuji Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
