Question about Sony Cyber-Shot DSC-W5 Digital Camera
How to Remove the button-sized lithium battery. em?
Posted by G.C.JainPaul . on
How can i reset factory setting on my sony dsc55 camera
Reset button on the camera
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Initialize or Reset option(s) in the camera menus
  • The menu layout is different between cameras so check the operating instructions.
  • In general, there will be a Reset or Initialize section within the menus of the camera.
  • Some cameras allow for resetting or initializing different options such as wireless settings, the settings used in taking the last picture, or all settings. Be sure to look at all available options in the product manual.
Manual reset process
Cameras manufactured prior to the year 2000 do not have reset buttons or options in the menus. Follow the steps below to reset:
    1. Turn off the camera.
    2. Remove the battery pack.
    3. Remove the button-sized lithium battery.
    4. Allow the camera to remain without power for 30 seconds.
    5. Reinsert the button-sized lithium battery.
    6. Reinsert the battery pack.
    7. Turn on the camera.
NOTE: If your camera is experiencing an issue and it is not resolved by performing the appropriate reset or initialize procedure above, service may be required.
Jan 06, 2015 | Sony Cyber-shot DSC-W55 Digital Camera
Error message "turn power off and on again" I did this and it did not work.
Performing a manual power reset (If your camera does not have reset button and initialize function)
Jan 07, 2014 | Sony Dsc-s2000 Cyber-shot Digital Camera...
Multi color circle lines on images
I suggest that you perform a manual power resetting and check the operation.
Feb 11, 2012 | Nikon COOLPIX S70 Digital Camera
My camera doesnt allow me to take photos, the lens doesnt work.
Most of the lens issues due to mechanical problem. some of the causes are dropping the camera.
Hard shake like keeping the Camera in the hand and jump through steps, Moisture condensation, Insufficient battery.. etc If If you feel that the issue is not with the above reason, try initializing the Camera. To initialize the Camera, please use the Initialize option under the setup 1 Menu.
If the issue persists, perform a power reset of the Camera.
Performing a manual power reset Turn off the camera. Remove the battery pack. Remove the button-sized lithium battery. Allow the camera to remain without power for 30 seconds. Reinsert the button-sized lithium battery. Reinsert the battery pack. Turn on the camera. If the issue persist, service is required.
Jan 07, 2011 | Cameras
The lens on camera doesnt work
Hard shake like keeping the Camera in the hand while jumping through steps, Moisture condensation, Insufficient battery.. etc If If you feel that the issue is not with the above reason, try initializing the Camera. To initialize the Camera, please use the Initialize option under the setup 1 or Main Settings 1 Menu.
Jan 07, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
HELP! I have the sony DSC S950, everytime I take a picture, the picture has this green, pink and blue horizontal line on it, and it is so lighty... pls. help me!
When shooting a subject with a strong light source, such as the sun, black lines or other noise may appear on the recorded image. This is called the smear phenomenon and is specific to the CCD of the camera; this is not a camera malfunction. To prevent this from occurring, do not shoot a subject with a strong light source directly.
If the issue persists with all shooting conditions, it may be an issue with the Camera.
Try initializing the Camera. To initialize the Camera, please use the Initialize option under the setup 1 Menu.
Jan 07, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
When I turn the camera on the screen shows a white light. No image
  1. Verify that the lens cap is not covering the camera lens.
  2. If operating the camera with a battery, ensure the battery is fully charged.
  3. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  4. Verify that the LCD screen is turned on.
  5. Adjust the LCD brightness control.
  6. Change the shutter speed or aperture settings.
  7. If the issue is not resolved, try resetting the camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
Jan 01, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Hi, The shutter on my sony dsc - p73 will not open all of a sudden is there any hope of being able to sort this?
I'm sorry that the shutter of the sony dsc - p73 will not open. I suggest that you perform a power reset and check the operation.
If the issue is not resolved, service will be requred.
Dec 13, 2010 | Sony CYBERSHOT DSCP100 Digital Camera...
Hello i have dsc-T300 it says lens is closed what can i do to turn it on.
This may be a real Flat Battery, what you could try is a replacement battery, if this doesn't fix it, then it must have developed an internal fault, and should be returned to the service agent for a quote for a repair.
Jul 18, 2010 | Cameras
Cat knocked my digital camera off the desk now the screen is blue
Try reseting your camera
  4. if you dont have a reset button try the manul reset below
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. hope this helps
Aug 02, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Open Questions:
See all Sony Cyber-Shot DSC-W5 Digital Camera Questions
Sony Cyber-Shot DSC-W5 Digital Camera Logo
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sony Camera Expert? Answer questions, earn points and help others
