Picture is OK but needs contrast ajusted,
There are actually two adjustment access holes (focus and contrast) on the back of that model. Here is a makeshift map...
On the back of the set mentally divide it to a left and right half. About the middle of the right half and around 4 or 5 inches up from the bench there will be two 1/8" holes. one on top of the other and about 2" apart. Slip a "pocket" sized flat head screwdriver into the lower hole and feel for the blade to enter the slot and gently turn either direction to adjust the contrast to your liking. The other hole above the "contrast" hole is for "focus" and really should be left alone.
The entire back cover can be removed by taking the four screws out of the corners and slipping it off. Then you can actually see the adjustment controls if you find getting that little screwdriver into the hole would be easier with it's clothes off...
*he smiles...*
SOURCE: Picture converges to the center -- "funnel" like
1) Solder any / all bad connections
2)troubleshoot,locate and replace any bad parts in pincushion
circuit....start with pin amp output.......
3)No problem found ?.........could be bad yoke.................T.
SOURCE: how do I access the menu without a remote?
You don't. A good "universal remote" available from Radio Shack (Phillips) for about $15 will provide access to all TV adjustments. Easy to program for all TV models, VCR's, DVD players, etc. About $35 + S&H for the Sharp remote replacement.
SOURCE: Want to see a free online manual for the Sharp
CRT-(Tube tv).Dosen't support HDMI cables.S-Video cable.Only on some a 27' and above.Mostly are R,Y,W RCA component cable support work best for the standard below 27" (CRT-tube-tv).
SOURCE: value resistor 719 of chasis serial :
I looked at the same chassis I have and the resistor has color bands green blue silver gold wich is a .56 ohm 5% 1/2 watt resistor
