Need to buy a pair of replacement carbon brushes for the motor of PW 1350 . Where to purchase carbon brushes/ name of motor- model?
Parts for Campbell Hausfeld can be found at www.chpower.com. Campbell Hausfeld does not however, sell motor parts for many of their tools. You would have to call their 800 number and speak with a parts person to determine availability. You may be able to purchase a close match at a local True Value hardware store. They sell a variety of brushes for many major brands of tools. Purchase a slightly larger set of brushes and sand them to size. If the connector is different, cut off the old connector and solder it to the new brush.
SOURCE: When trigger is engaged under pressure nothing happens.
Make sure all of the water is bleed out of it buy holding trigger down with motor not running until theres is not more bubbles or air that comes out..Make sure where the inlet for waters screen is not plugged..You may have to back flush washer to clean out or to unstick the pressure valve..Hope this helps you and have a great day
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
SOURCE: Does anyone know what the spark plug gap setting
Most gas engines will work fine at .030 to .035 sparkplug gap
SOURCE: on my campbell hausfeld water wizard 2000 the wand
It sounds like a blockage in the high pressure nozzle.
Ohio Carbon Industries, Inc. is a manufacturer and distributor of carbon brushes for nearly all electric motors. Call their sales dept. at 419-496-4456 or email at [email protected].
If you're still looking for carbon brushes, I know where you can get carbon brushes for sale. Be sure to give them a call or check them out and get as many as you need.
